D-Series Ninja
Ride: 90' Honda CRX Si
I live in the middle of nowhere, a place where I see more tractors on the road than cars. Yet somehow after changing my alternator out with one from an old D15 and taking one of my friends for a joy ride in my Rex, We stumbled upon two teenage asians and a old ass white guy with the hood up, on the side of the road with an
EVO!! It had the normal 4G63 and I asked them if they needed any help and they told me the hot pipe kept popping off and they were using some skinny clamps. I had some old turbo parts laying around the house about a block away so I ran and got them a new rubber fitting and two larger clamps. I was curious if it had been modified at all and they said it was a stock piece of shit and I asked how much boost... 25-30lbs is what they said they were running? Isn't that a little much for a stock evo or am I wrong? I would think with that much the pipe would have constantly been popping off or they could have detonated something. Anyone know how much boost a stock evo can take or should be at? |
Administrator
Ride: 318ti, dakota, genesis 2.0t
pretty sure stock evo runs 23psi. with a mbc, the range the said is certainly feasable.
it's a dinky ass turbo. my genesis runs up to 14psi stock with random low end spikes (ie, 5th gear at 30 mph) to 18psi and its still slow lol |
D-Series Ninja
Crazy, I wonder if they were just running it lean at 30psi or if they had anything to manage the fuel like a FMU or something. I did not even think about a manual boost controller. I would think they would be pushing around 350hp with that much!? I have a friend considering a 4g63 swap into a Del Sol, what do you think? I don't know if I want to see him attempt it and fail if it will cost him too much or be too much of a pain to install. I have seen a few of the swaps into crx's I think?
Administrator
you don't need to hack the fuel system on a car already designed for boost like using an fmu. the computer is already capable of reading boost and has maps beyond its stock rpm band and boost ranges. there's simple software out there to reflash evos.
EcuFlash - OpenECU |
#5 |
Administrator
oh, and putting a 4g63 in a civic/etc is just retarded and a pain in the ass.
its not orginal (been done 100s of times) its all custom wiring and mouting it will cost you a ton of money just to get it to turn on and not fall out of the engine bay hell, its not even that good of a motor just throw a bin it and don't be retarded |
#6 |
D-Series Ninja
That's what I figured you would say. I am a machinist but don't feel like trying to make mounts for him and then getting blamed if it falls apart. Maybe I can change his mind because money would be the biggest issue.
#9 | |
Ride: 88 Honda Civic HB
Stock, fuel is somewhat an issue though. He's pretty close if not already maxing out the injectors just by using the boost controller set at 19-21psi. Luckily, Evo's run a little rich from the factory. __________________
#12 | |
D-Series Ninja
#15 |
Token GM Guy
Ride: 91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
If you'd like to see an exploded view of your engine in person, then yes.
![]() __________________
Si vis pacem, para bellum There are no stupid questions, but there are a lot of inquisitive idiots. TWIN Turbo V8 CRX |
#16 | |
Token GM Guy
#17 |
that "dinky ass" turbo your talking about can make 350awhp-400whp(if it had the 10.5 hotside) with meth and high boost, around 27-28psi. It's a bad *ss turbo and full spool by 3k rpm
with the small 9.8 h.side and no meth I ran a 12.40 with basic bolt-ons. Evo's are awesome cars when modded right and when they don't break! haha If you can afford it, imho I thinks its the best DD for performance and comfort. The weak point in Evo/4wd Dsm's is the drivetrain. But when built (sheptrans.com) and done right , they can be made into some quick street cars. so to answer RICERACEREX: evo's come from the factory at 18psi and taper to 15ishpsi. With a simple mbc they can be set to run 20-22psi throughout the powerband, no tapering what so ever. there are a few fuel management options, ecuflash being the cheapest and most popular. as one of my sigs say....... I LIKE MY EVO BUT I <3 MY HONDA __________________
d0mestics are like tampons...every pussy needs one |
#19 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
tyler durden?
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
| Tags |
| crx, evo, honda, mitsubishi, turbo |
| 1986-1987 honda civic side marker sedan r side | RSS-Bot | Auctions | 0 | 08-14-2009 04:17 PM |
| 1990-1991 honda civic side marker hatchback r side | RSS-Bot | Auctions | 0 | 08-14-2009 04:17 PM |
| 1990-1991 honda civic side marker sedan r side | RSS-Bot | Auctions | 0 | 08-14-2009 04:17 PM |
| Road Side Smog Testing | jeffie7 | Members' Lounge | 7 | 03-09-2003 07:19 PM |
