Supercharger
Old 12-20-2003, 05:22 AM   #1
Rep Power: 16 wisemansoji is off the scale
I found a 97 b18b1 in a wrecker with a jacksonracing supercharger on it. I got a 2000 b16a2 in my 94 HB and I was wondering if this supercharger would do my engine some good. Cuz I can get all the partss I need for around 400$ I don't know much about superchargers I read a lil about belt timing and a few other things, does the compression of my engine need to be modified and what else would need to be changed on my engine for a jackson racing supercharger. I just use my car for every day driving and I'd like to get a lil more power outta my engine.
only nods till this date
Spoon header
skunk2 cam gears
aem intake
apexi cat back exaust
wisemansoji is offline   Reply With Quote
Old 12-20-2003, 05:31 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
it wont fit.
the ls and the b16 head bolt patterns are different.
Old 12-20-2003, 02:38 PM   #3
Rep Power: 14 simplyfast is off the scale
so a b18b1 IM wont bolt to a b16a head?
pick up the supercharger regardless, its worth more than $400. if you know anyone at your local machine shop they can actually fabricate an IM so you can use the jackson with your b16.
<span style=\'color:gray\'>A stock B16A runnin 24 lbs of boost? Egad, how does he do it? -what the bitches snicker
It's a little thing I like to call &quot;overlap.&quot; -quiets the pepboys mechanics</span>
<span style=\'color:blue\'>It's called left coast represent.</span>
simplyfast is offline   Reply With Quote
Old 12-20-2003, 04:03 PM   #4
ok, What all should I try to get.
Old 12-20-2003, 04:25 PM   #5
well ive always been told; read, that all b series parts can mix minus the bastard gsr head due to a different bold pattern. if a b18b IM cant swap over to a b16 head, then look around for a b16 IM. then with the IM and SC, go to a machine shop/fabrication shop and tell the guy what you need done. i would also tell him to place the SC slightly higher for a more direct shot into the intake runners, which will help power and atomization.
i think for right now you should get the SC and sit on it. maybe put it up for sale at auction sites and see if you can make money off of it. in the meantime, you should read about engine building techniques.
general rule is with more air you need more fuel. and with more comes possible detonation problems, which i highly doubt you would have to worry about with a stock JSC pulley.
Old 12-20-2003, 05:08 PM   #6
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Fuck it, get the B18B1 and pull the B16A2 out and replace with the SC'ed LS, what's the issue.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 12-20-2003, 06:20 PM   #7
Rep Power: 35 NotUrAverage_Si is off the scale
how bad was the wreck? anything wrong with the motor or SC? yeah that's true, it can be fabricated to fit the bolt pattern of the b16 intake manifold. otherwise sell it and save up for a JRSC for a b16.
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 12-21-2003, 04:06 AM   #8
so with a stock JRSC I won't need to do any internal work or play with my air fuel ratio.
Old 12-21-2003, 07:07 AM   #9
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Dude, just pull the WHOLE B18B1 w/ supercharger on it, out of the wrecked car, and put it in yours, sell you B16A2 for more than you buy the LS from the junkyard for, and go out and be faster.
95 CX|B16A2
Old 12-21-2003, 08:36 AM   #10
RETIRED
the JRSC comes with all the fmu stuff...
just install a feul pump... and you're done
Electric Supercharger Works? gobot420 Forced Induction 6 01-20-2004 01:36 AM
Centrifugical Supercharger For H22a/f20b JDMSpecAccordSir-T Forced Induction 5 06-06-2003 05:02 PM
Supercharger Or Supercharger? king_stu Forced Induction 31 04-01-2003 02:46 AM
Supercharger AccordGuy772 Forced Induction 1 03-20-2003 09:59 AM
Supercharger On A B18b Questions... mntnTEG04 Forced Induction 4 01-30-2003 05:05 PM
