Thinking of going Turbo
Old 02-12-2004, 04:24 PM   #1
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
Well i rode in my buddys turbo miata last night, and for a junk yard set up it was pretty quick.
So it got me thinking about boosting my car. My set up is a 90 integra with a b16. (i know i have a teg with a b16) When i say budget im thinking somewhere around $2000. My question is, if i wanted to start gathering parts for my budget turbo project, what would you guys use? Power goals are somewhere just north of the 200hp mark. Main think im looking for is mid range and a quick spool because we all know the b16 has no low end at all.
Thanks for the help.
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
Old 02-12-2004, 04:35 PM   #2
Banned
Rep Power: 0 Loco Honkey is off the scale
For your requirements, I'd use the following...
Thunderbird Turbocoupe turbo, T25, 14G, or a 42/48 T3 for the turbo.
SMIC from a DSM or an IC from a Probe GT/ MX-6 GT for the intercooler.
Simple log manifold.
Simple downpipe.
Charge pipes that are the same ID as the compressor outlet. I had 1.75" ID charge pipes on my '93 Si hatch and was making over 200 HP on the stock engine, for reference. Small charge pipes = quick spool.
Fuel management can be an FMU because your power goal is low.
Bump your ignition back 2-4° and you'll be fine.
Use plugs that are two steps colder than stock.
Contrary to popular belief, you CAN use high pressure fuel injection hose for the oil feed line, providing you use 360° fuel injection hose clamps. I used this in my hatch and had no leaking issues in the ~20,000 miles I drove it. It weeped some, but the weepage was equivalent to about one drop every 3000 miles. I did my oil feed and return lines for $20 using those materials.
Gauges are good- boost, oil pressure, AFG will set you right.
Most important tool you'll ever have: Your ears. Pay attention to ping/ knock/ detonation.
If you're a cheap bastard about it and Ebay everything, you could have it done for under a grand.
Loco Honkey is offline   Reply With Quote
Old 02-12-2004, 05:46 PM   #3
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
shelby turbo daytona's have nice FMICs. i think i am going to use one of those when i do my project.
any of the turbo's loco posted will be good for exactly whaat you want. try to find a good turbo that is internally gated. if you do any of them should be gated down to the power your stock block can handle.
saturn_boy96 is offline   Reply With Quote
Old 02-12-2004, 06:05 PM   #4
Yeah i hope i can run low boost on stock internals.
Power:
GReddy 4-2-1 Header
Suspension:
Old 02-12-2004, 08:37 PM   #5
Banned
All internal wastegates are set to around 7 PSI, +-1 PSI.
Old 02-12-2004, 09:27 PM   #6
JDMPlaya's Avatar
Ride:  2007 Camry / 2005 Acura MDX
Rep Power: 30 JDMPlaya is off the scale
Send a message via AIM to JDMPlaya Send a message via Yahoo to JDMPlaya
Hey loco I was plannin on running the AFC hack but my goals were similar with his, So I will be cool with an FMU if im going around 200 horses or so? I wouldn't need 450's would I ?
2007 Camry XE
2005 Acura MDX Touring Edition
JDMPlaya is offline   Reply With Quote
Old 02-12-2004, 10:25 PM   #7
Rep Power: 15 B18aCRX is off the scale
Send a message via AIM to B18aCRX
Not to threadjack, but would that setup and those turbos be good for a '90 B18a in a 88 CRX? Thanks
<span style=\"font-size:8pt;line-height:100%\">
<a href=\"http://www.hondaswap.com/forums/index.php?showtopic=35492\" target=\"_blank\">Hondaswap Vouch</a></span>
<a href=\"http://www.norcalcrx.org/forum/\" target=\"_blank\">Nor Cal CRX Club</a>
<span style=\"font-size:8pt;line-height:100%\">Bar Approved 1988 CRX LS</span>
<span style=\"font-size:8pt;line-height:100%\">1996 Accord LX</span>
B18aCRX is offline   Reply With Quote
Old 02-13-2004, 02:29 AM   #8
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
*any* turbo is good. But good, is a personal preference or opinion.
Me, I think they are tiny and a waste of time for the hassel/gain.
others, just want 50 more hp, and a tiny setup is perfect.
with an FMU, you use your stock injectors for the most part. in some rare cases, upgrading to 310s would be pretty much the most. Otherwise, you will flood to holy hell at idle, and generally, run way too rich.
Im thinking of buying a Toyota MR2 Turbo josh_isakson Other Vehicle Discussions 16 07-30-2004 08:35 AM
Is there a Supercharger kit chap_e77 Forced Induction 3 08-26-2003 07:09 PM
MY experience with my Turbo ZC LS/VTecEF9 HYBRID -> ED-EF / DA 13 07-31-2003 04:00 PM
Gt4 Y0! pissedoffsol Members' Lounge 33 06-18-2003 01:13 PM
difference between turbo sizes SnailOnARampage Forced Induction 4 11-12-2002 04:53 PM
