does anyone know what the thread size is for hte oil pressure sensor on the back of a b series block, is it 1/4 or 3/8 " its not metric right??
just looking to bid on a t fitting that says its 1/4". im gonna use common sense and geuss the thread is a really fine pitch too right?? also anybody ever use those golden eagle vacuum manifolds with the 6 ports on them?? it sounds to be helpful but didnt know if anybody could give any feedback on how well they operate or if they are accurate to mani. vacuum. [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] __________________
93' Del Sol 2000 B16A2 swap. garrett T3/T4 (.48/.60) Weapons of choice.. Innovate LC1 and Crome Pro Faze EL Engine management guages. |
RETIRED
block is 1/8" BSPT.
DO NOT try to use an NPT fitting on it, or you'll fubar you're block. you need a bspt to npt adapater. http://www.mcmaster.com/ part# 4092K81 Precision Threaded Type 316 SS Pipe Fitting 1/8" NPT Male X 1/8" BSPT Male Hex Nipple, 9100 PSI In stock at $4.44 Each i used the vac manifold....didn't have too many problems with it. just a pain in the ass to set up. |
<div class='quotetop'>QUOTE(pissedoffsol @ Oct 20 2005, 11:11 PM) Quoted post</div><div class='quotemain'>
block is 1/8" BSPT. DO NOT try to use an NPT fitting on it, or you'll fubar you're block. you need a bspt to npt adapater. http://www.mcmaster.com/ part# 4092K81 Precision Threaded Type 316 SS Pipe Fitting 1/8" NPT Male X 1/8" BSPT Male Hex Nipple, 9100 PSI In stock at $4.44 Each i used the vac manifold....didn't have too many problems with it. just a pain in the ass to set up. [/b][/quote] thanx B, yeah i think i might give it a shot, its only like 30 bucks on ebay and if keeps everything organized then its a good investement. ok thats mad cheap for hte adapter. noob question for ya, i know PT stands for pipe thread, but what does the "N" and "BS" stand for, just out of curiosity! thanx again! __________________
NPT = National Pipe Tapered
NPS = National Pipe Straight BSPT = British Standard Pipe Tapered |
#5 |
thanx bud! [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
