Trim? A/R?
Old 10-21-2005, 05:30 PM   #1
Go fast, Go Cheap
Ride:  Hybrid POWER!
Rep Power: 24 jimboburgess will become famous soon enoughjimboburgess will become famous soon enough
Send a message via AIM to jimboburgess Send a message via Yahoo to jimboburgess myspace
Can someone explain or point to a site that shows what the signifigance of trim and a/r are i really don't know
Resurrected Sol
http://hondaswap.com/auto-multi-medi...ted-sol-60210/
2003 Civic Hybrid (I'm a grown-up now)
www.myspace.com/burdenelectronica
jimboburgess is offline   Reply With Quote
Old 10-21-2005, 06:58 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 179 reikoshea has a reputation beyond repute
myspace
Hotrod.com has a really good article that touches on it.
http://www.hotrod.com/techarticles/engine/...rbo/index1.html
oh, and that is page 2, there is more to that article than just that.
Anime Informant
reikoshea is offline   Reply With Quote
Old 10-21-2005, 07:05 PM   #3
swanny's Avatar
Rep Power: 50 swanny is on a distinguished road
Send a message via AIM to swanny
Re: A/R http://www.honda-tech.com/zerothread?id=1023414
http://www.midwesthybrid.com
swanny is offline   Reply With Quote
Old 10-23-2005, 07:05 AM   #4
Rep Power: 12 BlueShadow is off the scale
For compressor wheels, trim is the ratio of inducer diameter vs exducer diameter. The inducer is the part of the wheel where the air enters it, and the exducer is the part of the wheel where air leaves. For compressor wheels the exducer is the outer diameter of the wheel, and the inducer is the inner diameter of the wheel. For turbine fans the inducer is the outer part of the wheel, while the exducer is the inner part of the wheel. See the pic I posted below to tell you which is which.
The rx7 link I provided tells you how to calculate the trim of a compressor wheel. Just a little fyi when calculating trims you can just calculate it in inches or mm it doesn't matter. Trim is just the ratio of ind/exd and the trim will come out the same whether you calculate inches or mm. The link also tells you how a higher or lower trim number determines where the compressor is the most efficient. Also check out the Garrett link and look atthe products menu and the tech menu. You can use the products->turbochargers menu to calculate the trim of the compressor wheels. Use the formula in the rx7 club site or Garrett site to calculate the trim.
http://www.rx7club.com/printthread.php?t=345518
http://www.turbobygarrett.com/
-1989 Ford Probe GT (stock, pos) **SOLD**
-1999 EBP Civic SI (modded) **SOLD**
-2001 EBP Prelude Base (almost stock) **SOLD**
-1993 VR RX-7 R1 (modded, 280 RWHP) **RIP**
-1991 Red CRX DX (turbo B18C in the works)
-1990 White CRX DX (stock)
BlueShadow is offline   Reply With Quote
Old 11-26-2005, 10:42 AM   #5
Rep Power: 17 B16CRX is off the scale
Send a message via AIM to B16CRX
good RX7 link. Bookmarked!
1991 CRX Si
PR3 B16A
62mm BBK TB
Boosted
B16CRX is offline   Reply With Quote
