I am looking into saving some $$$ by keeping my b18b, rebuilding it and adding a turbo. The final goal is to have a daily driver with weekend warrior options. I would like to hit 13.0 to 13.5 sec on the 1/4 mile. Suggestions on what parts to use for a rebuild (aftermarket or honda) and what to use for a turbo.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
RETIRED
13's are cake to hit. 7-8 psi on a normal size t3/t04e will get you there.
rebuild? well- you really don't even have to. I'd suggest getting a good fuel system/hondata instead. |
I don't have a lot of turbo knowledge whats a t3/t04e?
#5 | |
92 hatch, b18c block b16 head rsr GT-II exhaust, skunk2 valvetrain. skunk2 manifold <span style=\'font-size:14pt;line-height:100%\'><span style=\'color:red\'> Michael Moore...You've just been pwnd'</span></span> |
#6 |
RETIRED
yup- its a common turbo used on hondas... its a hybrid (1/2 and 1/2). t3 on the turbine side allows for pretty quick spool. t04 on the compressor side allows for more power potential.
E stand for the "cover" of the E housing. the B, E and S housings are common, with b being small (less power potential, quciker time to boost) and the S housing being huge (huge power, long spool time) Common T3 compressors: 40 trim (20lb/min -- haha...don't even think about it) 45 trim (21lb/min) 50 trim (30lb/min -- probably one of the most common on junkyard turbos, works well for SOHC and LS engines) 60 trim (34lb/min -- biggest "production" T3 compressor, excellent power on D series/LS) "Super 60" (36lb/min -- note: this is NOT the "60-1" compressor) Common T04B compressors: S trim (37 lb/min) V trim (48 lb/min) H trim (49 lb/min) Common T04E compressors: 40 trim (36 lbs/min) 46 trim (41 lbs/min) 50 trim (47 lbs/min) 54 trim (45 lbs/min -- note that the 54 trim flows less than the 50 trim) 57 trim (49 lbs/min) 60 trim (50 lbs/min) Common T04S compressors: 60-1 (flows a shitload, never seen a compressor map for it) 62-1 (bigger yet -- I believe this is a T04S compressor...correct this if it is wrong) Performance (listed in order of increasing performance): A T25 is a straight T25 turbo --> T25 turbine + T25 compressor A T28 is a hybrid T25/T3 turbo --> T25 turbine + T3 compressor A T3 is a straight T3 turbo --> T3 turbine + T3 compressor A T3/T04B is a T3/T04B hybrid turbo --> T3 turbine + T04B compressor (used in Drag kits) A T3/T04E is a T3/T04E hybrid turbo --> T3 turbine + T04E compressor (more performance than T3/T04B A T3/60-1 is a T3/T04S hybrid turbo --> T3 turbine + T04S (60-1) compressor |
#7 |
thanks good info. As far as a rebuild my cars has 170K and I am going with the worst cast first. That way if the engine gets inspected and its fine Im a happier camper. Who makes a reliable turbo setup for daily driving?
#8 |
What does everyone think of block guards???
#10 |
Alright Loco what you recommend for a turbo, and how much would it cost thru u?
| Is there a Supercharger kit | chap_e77 | Forced Induction | 3 | 08-26-2003 06:09 PM |
| Gt4 Y0! | pissedoffsol | Members' Lounge | 33 | 06-18-2003 12:13 PM |
| B18b For Turbo | pjecthatch | Engine Building | 2 | 03-07-2003 03:10 AM |
| Best Turbo kit for b18b? | BrainFood | Forced Induction | 13 | 01-24-2003 04:11 PM |
| Nitrouse And Turbo On B18b | orangecivic | Engine Building | 5 | 01-21-2003 12:07 AM |
