turbo b18b1 wont rev over 5krpms
Old 04-11-2009, 02:19 PM   #1
bigg86 is an unknown quantity at this point
Default turbo b18b1 wont rev over 5krpms
i just finished rebuilding my B18 and for some reason it wont rev past 4500-5krpms and if it does then the engine dies and shuts off. I cant downshift either or the same thing will happen... But i noticed when im in the freeway in 5th gear the car will drive just fine till about 5500rpms. i havent taken it past that tho...
Here are my mods:
84mm wiseco pistons
eagle rods
darton sleeves
micropolished n balanced crackshaft
inline four crack pulley
Extreme P & P head
brian crower stage 2 boost cams
brian crower dual springs + retainers
1mm oversized valves w/3 angle valve job
STR cam gears
sk2 intake manifold
sk2 70mm throttle body
3 bar map sensor
255lph walbro fuel pump
automotive fuel filter
automotive FPR
automotive fuel gauge
AEM fuel rail
275cc injectors (no boost yet)
external msd coil
MSD 6AL ignition box
apexi neo fmu (upgrading to s300 once i start boosting)
ram exhaust manifold
44mm tial wastegate
T4 custom turbo
3inch downpipe
3inch cat back
31x12x3 front mount
I only have about 200 miles in it since i rebuilt it and ive been driving it slow with no boost, but i noticed the other day that the car started holding back once it past 4kprms..... i really dont have any ideas at the moment of what it could be.... if you guys have any ideas or if anything like it happened to you, please let me know.... Thanks!
bigg86 is offline   Reply With Quote
96 Integra b18b1 DIY turbo kit? GraphikViolence Integra 4 09-11-2008 05:13 AM
b18b1 turbo??? phoenix19l Civic and del Sol - EG and EK 19 08-18-2008 07:19 AM
92DA ls/vtec swap - wont turn over - wont return key-5spd conversion as well. TurboColt HYBRID -> ED-EF / DA 18 08-18-2006 03:27 PM
F/S in OHIO LSVTEC PARTS... B18b1 block, GSR head, B18b1 head, Underdr 5speed4life Parts: For Sale/Trade/Wanted 0 11-27-2005 07:29 PM
Turbo Crx wont start NEED HELP??????? turbocrx2.0l Forced Induction 2 02-14-2004 12:34 PM
