Turbo Charged tranny
Old 01-01-2003, 05:00 AM   #1
Rep Power: 15 iowasmurf is off the scale
What's the best tranny for a turbo charged B series motor?
iowasmurf is offline   Reply With Quote
Old 01-01-2003, 05:24 AM   #2
Rep Power: 24 djextremity is off the scale
Send a message via AIM to djextremity
LS with LSD
djextremity is offline   Reply With Quote
Old 01-01-2003, 11:57 AM   #3
Why would the LS tranny be better, is it cause of the longer gear ratios that will let the turbo more time too spool and pull? Does anyone know of any websites where I can order trannies for a good price?
Old 01-01-2003, 12:37 PM   #4
Rep Power: 23 chet is off the scale
Send a message via AIM to chet
gsr transmission is better for boost. from my experiences an LS is just too long...and takes forever to make power.
what kind of transmission are you looking for?
i have a gsr transmission for sale...well its my dad's but he is entertaining offers right now.
its from a 97 gsr, had around 100k miles on it...shifted perfectly...no bad synchro's, was driven by some lady before she sold it to one of my neighbors, who ran the motor hot and sold it to me.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a>
chet is offline   Reply With Quote
Old 01-01-2003, 02:47 PM   #5
Rep Power: 19 cws13 is off the scale
Send a message via AIM to cws13
depends on turbo sizing, how fast you spool up. I would agree with the ls/lsd combo.
1320 Motorsports Athens,GA
<a href=\'http://www.1320motorsports.com\' target=\'_blank\'>1320 MOTORSPORTS</a>
cws13 is offline   Reply With Quote
Old 01-01-2003, 04:14 PM   #6
Rep Power: 15 Silver94Teg is off the scale
So a turbo with more lag would do better with a gsr tranny huh?
Silver94Teg is offline   Reply With Quote
Old 01-01-2003, 11:21 PM   #7
yeah, a tranny geared low with a slow turbo would take forever to build boost. Not that you would boost this car but for example: a customer had a vx hatch and had a shade tree replace his blown motor. He dropped in an si and took out the check engine light bulb. He comes in because it barely runs and after we got him the right ecu and wired everything, the thing took years to go through the rpm band. You could cruise on the hwy in 3rd. extreme example, but you get the point. It's why I think stock GS-T's are not too fun. Boggggg, boost-shift, bogggg.
Old 01-01-2003, 11:41 PM   #8
Hmm... now i'm at an impass. I have an ls engine and tranny and plan on boosting it with a t3 60-1 which is kind of laggy compared to the t3/t4 that i was originally planning on. Think i should go for a gsr tranny? Thanks.
Old 01-01-2003, 11:59 PM   #9
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
i disagree entirely.
IMO, the bigger the turbo, the more lag, the longer the tranny you want.
it sounds stupid- i dont know i dont have proof.
me, im going to run an LS.
I will also be running a t4 60-1 turbo though.
IMO, follow this chart for turbo.
small turbo- t3 or smaller, ITR tranny w/lsd
medisum - t3/t4 hybrids - gsr w/quaiffe lsd
large turbo - t4 and 60-1 series (t3 or t4) - ls w/ quaiffe LSD
notice no b16s. the differentials are physically smaller and are said to hold less power before breaking.
for your application of the t3 60-1, i say go ls with the lsd.
the 60-1 are bigger turbos.
Old 01-02-2003, 03:44 PM   #10
But if you're turbo is larger and makes more power up-top, wouldn't you want a tranny that can keep you up there? But on the other hand an ls tranny would provide more gradual boost from the turbo for better drivability. Hmm, now i'm really confused.
Old 01-03-2003, 01:02 AM   #11
There are a ton of factors. A matter of preference I guess. Small turbo/high gearing is realevent in a way too. A small turbo supports smaller horsepower, so why not get it there quick with the ITR, you won't have a ton of taction problems. Try having a bigturbo with well matched exhaust piping for mamimum spool up with a short gear ratio tranny and you will sit still while you turn your tires to liquid. A massive horsepower onslaught too quick is bad us FWD guys. How you are going to drive her will be the end result in your choice. Turbo lag is your friend in certain applications.
Old 01-03-2003, 04:49 AM   #12
RETIRED
holy shit! SOMEONE fuinially agrees with me!!!
what do you think of my chart? would follow a similar guideline?
Old 01-03-2003, 10:09 PM   #13
being that none of us have that kind of cash for traction enhancements-definately. It's the only affordable combat against physics we have at our disposal. P.S. to all: forgive my spelling on that last post- 2 mutch beer mak mee spel gud.
Old 01-04-2003, 02:22 AM   #14
Rep Power: 15 BrainFood is off the scale
I agree that lag can be your friend as far as traction is concerned but it can also be the enemy a lot of the laggy setups I have seen (mostly single turbo supras) hit so hard when boost comes on that it causes traction problems, linear power would be ideal, for instance with an apexi avcr you can set the boost lower in the lower rpms and then gradually increase the boost through the rpms and even throught the gears. its a shame that the boost controll doesnt work worth a damn but it is a good idea none the less.
BrainFood is offline   Reply With Quote
Old 01-04-2003, 02:23 AM   #15
Rep Power: 17 Integra1990 is off the scale
Send a message via AIM to Integra1990 Send a message via Yahoo to Integra1990
what does quaiffe mean?
LS/t
Integra1990 is offline   Reply With Quote
Old 01-04-2003, 03:27 AM   #16
its a brand name
Old 01-04-2003, 02:10 PM   #17
ahhh ic, ive searched ebay and ebaymotors for lsd trannies, and they r a lil hard to find, anyone kno of any good sources for lik a gsr lsd tran?
LS/t
Old 01-04-2003, 02:52 PM   #18
Retired OG
Ride:  Integra, Tahoe
Rep Power: 43 kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
just get a regular gsr tranny and buy an aftermarket LSD.
Kyle I. Collins, PmD.
kyleirwin is offline   Reply With Quote
::Testing Waters:: '95 Turbo d16z6 175WHP @5000RPM steeze Parts: For Sale/Trade/Wanted 6 01-09-2005 06:12 AM
1994 Civic Hatch turbo, extra motor, and tranny, p annihilation Vehicles: For Sale/Trade/Wanted 5 07-02-2004 02:41 PM
WTF my Tranny is bleeding!?! Citizen_Insane General Tech and Maintenance 5 05-04-2004 02:53 PM
WTB 90 ex/si tranny and TD04 turbo ckyhimself Parts: For Sale/Trade/Wanted 4 04-24-2004 04:45 PM
MY experience with my Turbo ZC LS/VTecEF9 HYBRID -> ED-EF / DA 13 07-31-2003 04:00 PM
