turbo d16y7.. breakup & intake pipe comes off
Old 08-17-2008, 06:16 PM   #1
daGSRhatchNEPA's Avatar
Ride:  93 acura integra
Rep Power: 5 daGSRhatchNEPA will become famous soon enough
Send a message via AIM to daGSRhatchNEPA
Exclamation turbo d16y7.. breakup & intake pipe comes off
okay..i have a 96 civic with a d16y7.
Q: For some reason my intake piping blows off or comes off while driving it?
* The Engine also starts to Break Up @ Full Throttle around 4,000 rpm?
* I already adjusted the timing 1 tooth back to retard but now i am out of ideas
i have never had this problem b4.??!!
Need Help ASAP. Thanks~lou
daGSRhatchNEPA is offline   Reply With Quote
Old 08-17-2008, 08:16 PM   #2
I can't feel my face
Ride:  96 Civic - LS-T, 1989 Volvo 760
Rep Power: 51 Matts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud ofMatts96HB has much to be proud of
Send a message via MSN to Matts96HB myspace
Hmm, CEL on?
How bout the tune?
And as far as the intake piping blowing off, sounds like you have it routed a little rough or you need some new couplers/clamps.
96 NBP Hatch
89 Volvo Wagon
Matts96HB is offline   Reply With Quote
Old 08-17-2008, 10:37 PM   #3
cel on?
THE car was tuned with a neptune chip. only thing i did since the last tune was change the head and gasket. the car is fine @ idle but then when your driving through the gears you have to almost feather the gas pedal... the car has a 255 welbro fuel pump and 550 cc injectors... im thinking it may be dumping fuel.../?? only thing i can think of is getting a fuel pressure regulator at this stage.. idk im so lost with this 1. it ran fine with the other head but now its just a headache... any buyers LOL.
Old 08-18-2008, 02:40 AM   #4
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 101 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Originally Posted by daGSRhatchNEPA View Post
... any buyers LOL.
How much....
Looking for a P28 and B-series turbo parts, PM me.
Old 08-18-2008, 11:20 AM   #5
9psi
Old 08-18-2008, 01:28 PM   #6
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 10 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
so you changed the head, anything done to either head not done to the other head, like 5 angle, port and poslish. thicker head gasket? adjustable fprs are garabge
t3t4delsol is online now   Reply With Quote
Old 08-18-2008, 01:43 PM   #7
Von Europa
awptickes's Avatar
Ride:  1999 Civic EJ9, 2003 Civic EX Coupé
Rep Power: 55 awptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant future
So, the pipe blows off.
Do you have a blow off valve?
As for breaking up at about 4k, have you had it tuned after the new head? Each head is unique.
A tune for one engine is only a basemap for another.
awptickes is offline   Reply With Quote
Old 08-18-2008, 05:50 PM   #8
Fa-Q
newb's Avatar
Ride:  '98 Z28
Rep Power: 33 newb has much to be proud ofnewb has much to be proud ofnewb has much to be proud ofnewb has much to be proud ofnewb has much to be proud ofnewb has much to be proud ofnewb has much to be proud of
Send a message via AIM to newb myspace
^ Werd. If all your parts besides the head are the same, and theyre in the same condition as they were on the last setup, then the problem is not coming from any mechanicle part, its coming from the ECU.
Locate approximately as shown
"I'm a bad man." -Cassius Clay
Originally Posted by Battle Pope View Post
this thread makes me facepalm.
newb is online now   Reply With Quote
Old 08-18-2008, 05:52 PM   #9
Resident Fat Ass
George777's Avatar
Ride:  90 Hatch, 91 Rex, 85 Yamaha Virago, 82 CB900F Supersport
Rep Power: 58 George777 has a brilliant future
Originally Posted by efhondakid View Post
How much....
9psi
I think he was responding to how much for the car, not how much boost...
George777 is online now   Reply With Quote
Old 08-18-2008, 11:23 PM   #10
cel on?
Do you have a check engine light on? CEL stands for Check Engine Light
If so, get the codes scanned immediately. Start with the simple stuff.
If no codes, I'd be pointing my finger at the tune at this point, provided everything else is done right. Have you checked for boost leaks? Whats your Air Fuel Ratio in boost? Out of boost?
Before you go and get an FPR, try getting a wideband o2 sensor. That way you can tell what is going on with the Air Fuel Ratio.
96 NBP Hatch
89 Volvo Wagon
Old 08-19-2008, 08:55 AM   #11
My name is Byron.
efhondakid's Avatar
Driving your car around while its running like it is is a great way to make a really big expensive paper weight. And if it was tuned, you swapped the head it will need to be tuned again, like said earlier.
Old 08-20-2008, 09:37 AM   #12
turned out the waste gate was getting sticking. but problem solved.. thanks. the car is posted on craigslist for sale somewhere ill see if i can find it and copy in the link, the car should have 306hp last dyno tune~lou
Tags
boost, breakup, intercooler, turbo civic
Forum Jump
d16y7 turbo??? sz520player Civic and CRX - EW 0 01-03-2007 05:10 PM
anybody turbo a d16y7? allbottledup Forced Induction 10 03-21-2006 05:40 PM
intake swap to d16y7 Uppertorso ECU's, Electronics, and Tuning 1 03-02-2005 12:24 AM
turbo d16y7? japearl Forced Induction 5 07-28-2004 04:37 PM
Intake pipe bypass device peanut Forced Induction 1 11-27-2003 08:37 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
