turbo d16y7 running like crap
Old 04-20-2006, 06:30 AM   #1
Rep Power: 0 95turbodel is off the scale
hi im running a d16y7 in a 95 civic ex with a t3 turbo, ac autotechnic fuel rail, fmu, and a fuel pump. it bogs out at 4500 to 5000 rpm tryed a 94 lx ecu and it does the samething tryed a p28 ecu samething. what do u think it is?
95turbodel is offline   Reply With Quote
Old 04-20-2006, 07:57 AM   #2
Nick Go FAST!!
Turbo&Auto's Avatar
Ride:  09 Cobalt SS/TC
Rep Power: 87 Turbo&Auto has a reputation beyond repute
Turbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond repute
Send a message via AIM to Turbo&Auto myspace
Most likely the FMU is making it too rich. Do you have a Wideband O2? That would tell you right away.
www.BackyardTurbo.com
Turbo&Auto is offline   Reply With Quote
Old 04-20-2006, 09:59 AM   #3
Rep Power: 15 preludebuddy is off the scale
Send a message via AIM to preludebuddy Send a message via Yahoo to preludebuddy
ditch the fmu and get tuned.
preludebuddy is offline   Reply With Quote
Old 04-20-2006, 08:08 PM   #4
<div class='quotetop'>QUOTE(Turbo-n-Auto @ Apr 20 2006, 05:57 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I dont have a wide band o2 and where do i find one.
Old 04-21-2006, 12:34 AM   #5
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Any shop that actually tunes with a dyno should have one.
Old 04-24-2006, 03:20 PM   #6
Rep Power: 13 spydy43 is off the scale
FMU can cause your injectors to leak whick makes your car bog down cause its too rich.
spydy43 is offline   Reply With Quote
Old 04-25-2006, 10:48 PM   #7
Calesta's Avatar
Ride:  2003 S2000
<div class='quotetop'>QUOTE(spydy43 @ Apr 24 2006, 02:20 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
That's only part of it... and they'll only cause your injectors to leak if you're overpressuring them.
Most of the time you really just need a good tune, that's all. Timing is key.
Old 04-26-2006, 02:49 AM   #8
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
werd to everything that was said. ditch the FMU. its crap.
nothing compared to a real tune.
Anime Informant
reikoshea is offline   Reply With Quote
Old 04-26-2006, 04:48 PM   #9
<div class='quotetop'>QUOTE(Calesta @ Apr 25 2006, 10:48 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Doesn't a FMU constantly over pressure the injectors when you are in boost? All I know is shortly after boosting with the FMU in my car the car would bog at low RPMs or when I hit the throttle and I could smell excess fuel because of the injectors leaking.
Old 04-26-2006, 09:27 PM   #10
Calesta's Avatar
Ride:  2003 S2000
Yes, it does overpressure while in boost- that's how they work. They're generally not bad for low boost setups that don't make too much power because you're not overstressing the injectors, but for anything with real power expectations, using a RRFPR or FMU is just a bad idea.
