turbo questions
Old 10-01-2008, 08:19 PM   #1
Ride:  89 honda crx si and 94 chevy s10 4x4
sevenhillsbilly will become famous soon enoughsevenhillsbilly will become famous soon enough
Question turbo questions
first off do i absalutely have to water cool my turbo if i get one with the option of water cooling it and seccondly how hard is it to run the lines off of the turbo to the radiator and what not?
sevenhillsbilly is offline   Reply With Quote
Old 10-01-2008, 08:25 PM   #2
FI FTW.
Matts96HB's Avatar
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
First off, the lines will not come from the radiator.
Usually it's tee'd off of the thermostat "tube" on the back of the block.
If the turbo is meant to be watercooled, it had better be watercooled.
Matts96HB is offline   Reply With Quote
Old 10-01-2008, 09:29 PM   #3
so with the water line you run off of the thermo tube and to the turbo and the return line goes where?
Old 10-02-2008, 03:18 PM   #4
FI FTW.
Matts96HB's Avatar
I can't remember exactly how my friend had it (LS-VTEC-T with a little DSM turbo), but I think the return went somewhere farther down the line from the water pump. I can't remember exactly where, nor can I advise you on where to put the return. But I would recommend running the feed from there, yes.
Old 10-14-2008, 07:05 PM   #5
ok well i will try to put the return somewhere inbetween one of the lines somewhere after ther thermo tube or somthing
Old 10-20-2008, 12:53 PM   #6
where would the return line run for the water cooling part
Old 11-18-2008, 05:57 PM   #7
goldgeen90ef
Ride:  96 civic cx ,95 celica battle daily grinder, chuck taylors
goldgreen90ef has a spectacular aura aboutgoldgreen90ef has a spectacular aura about
myspace
my b18 turbo had in the fits valve lines on the throttle body...easy hook-up!
goldgreen90ef is offline   Reply With Quote
B18C1 Swap Questions and Gauge/Cluster Swap Questions |Chaz| HYBRID -> EG-EK / DC 14 03-22-2008 12:36 AM
smog ref questions and jdm b18b questions cbryde1212 HYBRID -> EG-EK / DC 3 05-14-2007 09:21 PM
D16 Turbo Questions.... slow_talon Engine Building 0 03-14-2007 12:16 AM
a few turbo questions breed Forced Induction 1 08-16-2005 05:27 PM
D16 turbo questions SolLess16 Forced Induction 12 08-20-2003 06:50 PM
