hey another question i guess i should've asked before, on the top port of the wastegate, the one that's for a boost controller, if i don't use it, should i plug it? b/c i have a blue stripe spring in the wastegate now (which is supposed to be a 5psi turbonetics spring) and all my lines are hooked according to the above diagram. the only difference is that the top port isn't plugged. it has the 1/8 npt to 5/32 vac nipple that is open to the atmosphere. now when i drive my car the car spools to 10-12 psi and i let off bc i don't wanna tear nothing up. should that top port be plugged? or do i have a 10+ psi spring in the wastegate? i'm going to take out the spring and measure its uncompressed height along with its outer dimensions so i know whether or not i have a tial big blue which is 14.5 psi!! i hope i dont have one that big, if so i'm selling that joker and getting like a 7psi spring. also, i have a turbonetics evolution wastegate (38mm) if that helps any.
