turbocharged ready to nitrous
Old 11-05-2003, 01:08 PM   #1
sooboss is an unknown quantity at this point
problem solved
sooboss is offline   Reply With Quote
Old 11-05-2003, 01:16 PM   #2
rudeludenotmeanthough is off the scale
what are your internals? Just curious
rudeludenotmeanthough is offline   Reply With Quote
Old 11-05-2003, 01:37 PM   #3
this is old
Old 11-05-2003, 02:29 PM   #4
GSRCRXsi's Avatar
GSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to behold
its sleeved and you have a block guard??
Old 11-05-2003, 02:46 PM   #5
NoJokE is off the scale
Send a message via AIM to NoJokE
where does it say he has a blockguard?
NoJokE is offline   Reply With Quote
Old 11-05-2003, 02:47 PM   #6
sorry i ment block guard.. had some people yapping at me here at work..
Old 11-05-2003, 02:53 PM   #7
GSRCRXsi's Avatar
still, you have a block guard and its sleeved?
Old 11-05-2003, 03:11 PM   #8
Just the guard. Not sleeved.. I am not trying to prove anything just need info.......Need help tuning the nitrous. Why....... its parted together the solinoids,switches, jets and lines.. but all NOS products.. So just need to know what jets guys are running for a 60 shot any one... with turbo...
Old 11-05-2003, 07:29 PM   #9
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
550s? you're out of fuel man. end of story.
wtf does closed 34% mean? 66% duty cycle? no way. you have to be topping those things way out.
550s are good for, oh, 250-300 whp tops.... and you won't run 11s with that.
i think you have a fuel problem....
be it a pump to get it there, a line to feed it, or an injector to deliver it.
Old 11-05-2003, 09:01 PM   #10
liquid00meth is off the scale
Send a message via AIM to liquid00meth
Indeed man. If you ran the exact same time that could tell you one of 2 things.
1.) you just happened to have a worse run even with extra hp.
2.) The nitrous your adding isn't doing shit because there isn't enough fuel to burn, ie, the efficieny is already so high that nitrous isn't making any "new" power.
so, when you hit that switch, you could actually be running way lean? which is not good.
What turbo are you running with 21 psi??
liquid00meth is offline   Reply With Quote
Old 11-05-2003, 09:14 PM   #11
Banned
Loco Honkey is off the scale
You're not running 21 PSI on your stockr ods, which you say you have in there..
Loco Honkey is offline   Reply With Quote
Last try... ITR Manifold direct port nitrous setup radnulb Parts: For Sale/Trade/Wanted 3 06-29-2004 11:11 AM
Nitrous Kit for B16 CarAudiophile Forced Induction 11 06-11-2004 04:33 PM
d16z6 with nitrous oxide? tphan4 Forced Induction 8 04-09-2004 06:53 PM
Cautions With Nitrous SpyOneUSN Members' Lounge 10 06-11-2003 03:01 PM
What Brand Of Nitrous? endlesszeal Forced Induction 2 04-21-2003 01:31 PM
