Vented hood for cooling SC?
Old 08-03-2009, 05:54 PM   #1
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
Default Vented hood for cooling SC?
superchargers get hot.... im wondering is there any real advantage to using some sort of vented hood? are any of them functional? and if so, anyone know of a good one for a DC?
mdpsEG is offline   Reply With Quote
Old 08-03-2009, 05:55 PM   #2
wwtdd?
95b16coupe's Avatar
Rep Power: 215 95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
it wont get hot enough to need a vented hood. a stock hood works just fine. compare to all the cars with oem superchargers. if anything, you could get a cold air intake to lower the temps a little.
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic.
95b16coupe is offline   Reply With Quote
Old 08-03-2009, 06:35 PM   #3
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
Rep Power: 88 newb has a reputation beyond repute
newb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond repute
Send a message via AIM to newb myspace
You could always pack a bag of ice in a cooler in the trunk.
Dont know of any heat exchanger hoods for a teg though.
Locate approximately as shown
"I'm a bad man." -Cassius Clay
Originally Posted by Battle Pope View Post
this thread makes me facepalm.
newb is offline   Reply With Quote
Old 08-03-2009, 06:56 PM   #4
Token GM Guy
double0Si's Avatar
Ride:  91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
Rep Power: 119 double0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
double0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
myspace
Pull the rubber seal off at the back of the hood. Its an old racer trick. It creates some turbulence at the windshield but if you're not gonna be going for a land speed record anytime soon im sure you'll be fine.
Si vis pacem, para bellum
There are no stupid questions, but there are a lot of inquisitive idiots.
TWIN Turbo V8 CRX
Originally Posted by 93civicracer View Post
I'm a real enthusiast for Japanese cars, I like the small things here n there that are different on jdm vehicles like lips, foglights, and the tiny differences especially the emblems for some reason.
double0Si is online now   Reply With Quote
Old 08-15-2009, 04:59 AM   #5
benson1121's Avatar
Ride:  GSR Del sol
Rep Power: 0 benson1121 is infamous around these partsbenson1121 is infamous around these parts
myspace
actually its recomended to use short ram. you could intercool it, but if you read on JRSC's website they say youll get more power by using a ram air, and no you do not need to worry about cooling it, it dosent get hot enough to worry about it.
benson1121 is offline   Reply With Quote
Old 08-15-2009, 12:37 PM   #6
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
I was running a cold air intake and 10 psi. I never had issues with crazy intake temps like people seem to complain about. I guess I did notice a little heat soak issues when I made back to back runs at the drag strip. I'd look into a water injection kit. Seems that they have the same performance benefit of the LHT with much less cost.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 09-21-2009, 09:46 PM   #7
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
Jackson racing superchargers do not require any type of external cooling, even if you do a setup that directs airflow over the body of the manifold or the charger itself you are wasting your time. The only 2 ways to cool the jrsc is water/meth or lht, on the stock charger with 8-10psi you are only going to gain about 20-25 hp I would recommend the lht tho if you plan on surpassing the 11psi barrier.
As far as heat soak goes, its inevitable, get a cooler temp thermostat and try to keep the engine cooler, that will help out some.
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6
doing it myself!
6/1/09 RHD on the road, now time for Body Shop
7/10/09 jackson gsr into rhd+hondata
91 rex ls/vtec
b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER!
13.881@102 on street tires
Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some
reptation, then give 'em a point!---,
welfare is offline   Reply With Quote
Old 09-21-2009, 11:15 PM   #8
Token GM Guy
double0Si's Avatar
myspace
When its getting hot just get out and spray cold water on it with a hose! Then stand back and watch the show!
TWIN Turbo V8 CRX
Old 11-16-2009, 07:30 PM   #9
Rep Power: 14 78civic will become famous soon enough
You could run an oil cooler before it gets to the S/C. That and running a good synthetic like Amsoil or Mobile could drop operating temps considerably.
E
"If you can read, thank a teacher"
"If you can read it in English, thank a VET"
78civic is offline   Reply With Quote
Old 11-16-2009, 08:08 PM   #10
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Most vented hoods aren't function, or as function as others, especially for our Honda's where the engine is in the way.
If you want to cool the JR, just use water/methanol injection.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 11-16-2009, 09:40 PM   #11
mdpsEG's Avatar
my engine runs cooler than ever after building it and installing the supercharger... i still have the stock radiator too. i do need to do something for the high IATs though, meth injection is high on the list.
92 93 94 95 honda civic dx lx ex racing hood vented d1 RSS-Bot Auctions 0 07-01-2009 04:17 AM
88 89 90 91 honda civic crx dx si lx racing hood vented RSS-Bot Auctions 0 05-10-2009 12:03 AM
92 93 94 95 honda civic dx lx ex racing hood vented d1 RSS-Bot Auctions 0 05-10-2009 12:03 AM
88 89 90 91 honda civic crx dx si lx racing hood vented RSS-Bot Auctions 0 04-20-2009 09:17 PM
88 89 90 91 honda civic crx dx si lx racing hood vented RSS-Bot Auctions 0 04-11-2009 09:17 PM
