Vitara Piston's Question...
Old 06-08-2008, 10:56 AM   #1
MJ93Hatchback is on a distinguished road
Default Vitara Piston's Question...
This s def. a Noob question and I know they are on ebay which a lot of people are strongly against but are these legit YCP Vitara Pistons?
eBay Motors: Vitara Turbo Pistons for Civic CRX Si D16 ZC Rings D16Y (item 180250224431 end time Jun-11-08 06:01:16 PDT)
MJ93Hatchback is offline   Reply With Quote
Old 06-08-2008, 11:20 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
You should check the threads on Honda-Tech by TurboPanda and make sure that they're the right brand of piston.
Old 06-09-2008, 04:11 AM   #3
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
t3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rough
Vitara Pistons are out of suzuki vitaras, same size bore, just a lower compression ratio
t3t4delsol is offline   Reply With Quote
Old 06-11-2008, 09:52 PM   #4
Calesta's Avatar
Ride:  2003 S2000
Yes and no. The Vitara pistons that everyone likes to use are not the OEM pistons. They're an aftermarket piston with a different aluminum composition than stock.
Old 06-11-2008, 10:42 PM   #5
Thumbs up
yeah, I am not going with those one's from the link anyways...from what I understand the YCP vitara pistons actually have a lower compression thn 8:5:1 like a lot of them say so...thanks for the responses though
Old 06-14-2008, 11:35 AM   #6
Calesta's Avatar
Ride:  2003 S2000
Old 08-19-2008, 03:54 PM   #7
DelSolJohn is on a distinguished road
the YCP Vitara Pistons on ebay are legit - I have those exact same pistons in my trubo d16z6. I am have been running 14psi on a T28 turbo for 2 years now and have had no problems what so ever. although, I do have the S200 and its tuned. that makes the world of difference.
DelSolJohn is offline   Reply With Quote
vitara d16 BoostedSol Forced Induction 28 09-10-2008 02:54 AM
d15 d16 vitara turbo pistons low compression RSS-Bot Auctions 0 01-13-2008 11:43 PM
YCP 75.5mm Vitara pistons & Rings. Civic/CRX D16 RSS-Bot Auctions 0 01-05-2008 10:53 PM
Max boost on Vitara pistons xRONINSxROGUEx Forced Induction 15 12-21-2007 08:48 AM
Help with D Series Vitara setup jOnZ Engine Building 3 11-29-2007 08:47 PM
