Wastegate or BOV, or both?
Old 06-24-2008, 07:39 AM   #1
Von Europa
awptickes's Avatar
Ride:  1999 Civic EJ9, 2003 Civic EX Coupé
Rep Power: 55 awptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant future
Default Wastegate or BOV, or both?
Ok, so I understand how they both work. They both work differently, so this raises the question, which one is more effective on a low-boost application?
I'll be using a FMIC'd T25 in my EJ9 civic. (link in signature)
I'm planning on a recirculating BOV, to let the turbo free-spin instead of surge. If I do this, I need a wastegate, right?
If I use an atomsphere-vented BOV, then can I get away without using a WG?
awptickes is offline   Reply With Quote
Old 06-24-2008, 07:59 AM   #2
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 10 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
more the likely the t25 will have a internal wastegate installed, wastegates release exhaust pressure. the wastegate is required
I dont know what manifold your using but most will have a external flange for the wastegate, if your planning on using the internal wastegate your going to need to use a block off plate on the flange. If you want to bypass the internal wastegate and use a external you will need to take off the exhaust side of the turbo and weld the wastegate plate open
the bov is also required, because it will release the pressure in the charge pipes when you close the throttle plate.
also I would vent to the atmoshpere
t3t4delsol is offline   Reply With Quote
Old 06-24-2008, 08:12 AM   #3
Von Europa
awptickes's Avatar
Ok, cool. Thanks.
Old 06-26-2008, 03:57 PM   #4
Slave to the EF
LudeBoy's Avatar
Ride:  91 EF Hatch
Rep Power: 11 LudeBoy is on a distinguished road
Send a message via AIM to LudeBoy Send a message via MSN to LudeBoy
Not required... But I would use one if you want your turbo to last.
LudeBoy is offline   Reply With Quote
Forum Jump
wastegate htchbck527 Forced Induction 4 04-01-2007 09:49 AM
wastegate lickety_slickjj Forced Induction 2 11-24-2006 02:37 AM
t28 wastegate StealthMode Forced Induction 16 11-03-2004 12:55 AM
wastegate help SolPWR Forced Induction 2 01-14-2004 11:13 AM
Wastegate Q NewAgeCivicz Forced Induction 5 04-16-2003 01:56 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
