Wastegate/Turbo question
Old 05-13-2008, 06:36 PM   #1
JDM jOn
Ride:  95 Civic CX
Rep Power: 7 jOnZ is on a distinguished road
Send a message via AIM to jOnZ myspace
Default Wastegate/Turbo question
How could I run my external wastegate spring by not connecting the vacuum line to the turbo because my turbo dont have the nipple on it for the vacuum.
Originally Posted by 88blacksi View Post
I then shifted to 3rd and rev it to 8000rpm then by 4th I rev to 7000rpm and I zoomed by her. VRRRRRRRRRROOOOOOOOOOOMMMM.
Then vtec was like AAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHH HHHHHHHH!!!!!!!!
jOnZ is offline   Reply With Quote
Old 05-13-2008, 06:51 PM   #2
Rep Power: 8 amadeuscr will become famous soon enough
You can use the intake manifold vacum line but you need a check link on that line cause you can't put vacuum on the actuator , only pressure ! ,
pd: I am not really sure if that's the line you refer to !
Ride:
B16A JDM SiR-II - Hatch 92
- WISECO Piston Kit STD
- Eagle Rods
- Walbro 255lph
- AEM Wideband
- CROME PRO
- T3/T4 Turbo Kit - RamHorn Style
- DSM 450cc Injectors
- TiAL 38 MM External WasteGate
- Integra Front Brake System
- Mugen Valve Cover Red
- NGK Iridium Spark Plugs
amadeuscr is offline   Reply With Quote
Old 05-13-2008, 10:01 PM   #3
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 16 t3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rough
most turbos atleast have a screw on the compressor housing, take out the screw and buy a nipple at the hardware store that has the same threads
t3t4delsol is offline   Reply With Quote
Old 05-14-2008, 12:51 AM   #4
senior member
HondaElite's Avatar
Ride:  92 civic coupe
Rep Power: 8 HondaElite is on a distinguished road
Send a message via AIM to HondaElite
this is my boys kit..theres no screw on it..they mighta filled it or sumthin....what about the red hose the goes to the t/b from the charcoel can..could he run it from there? and have the bov to the other vacume behind the i/m?
~sold out seats to hear biggie smalls speak~
HondaElite is offline   Reply With Quote
Old 05-14-2008, 02:14 PM   #5
my cars go fast
SLOWdelawareEG's Avatar
Ride:  ED8
Rep Power: 10 SLOWdelawareEG will become famous soon enoughSLOWdelawareEG will become famous soon enough
run it to intake manifold vaccuum source
SLOWdelawareEG is offline   Reply With Quote
Old 05-14-2008, 02:17 PM   #6
Nick Go FAST!!
Turbo&Auto's Avatar
Ride:  09 Cobalt SS/TC
Rep Power: 87 Turbo&Auto has a reputation beyond repute
Turbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond repute
Send a message via AIM to Turbo&Auto myspace
T off of the fuel pressure regulator vacuum line or the brake booster. Ive ran vac/boost to a WG without issues. Ive also heard that it shouldnt see vac though like someone mentioned.
www.BackyardTurbo.com
Turbo&Auto is offline   Reply With Quote
wastegate question spoolin@idle Forced Induction 5 11-30-2006 10:45 AM
Wastegate Question YangpaNemsay Forced Induction 2 12-25-2004 06:17 PM
wastegate mounting question spdr Forced Induction 1 05-14-2004 05:59 PM
Tial Wastegate Install question RFHOMI2U Forced Induction 2 09-27-2003 11:44 PM
Major Wastegate Question! DylanTheKid Forced Induction 8 06-13-2003 11:17 AM
