| | LinkBack | Thread Tools |
| | #26 | |
| Senior Member | Quote:
this is why toda makes cams for vtec heads, because they can utilize a huge vtec lobe that makes great power at higher rpm's. now if you start having crazy lift/duration at low rpm's you'll just flood the engine and the right burn won't be taking place. | |
| | #28 |
| Senior Member | the gears themselves are honda gears which are the same strength. the differential and the fact that ls transmissions have single cones or one synchro between each gear while the gsr transmission has double synchro's between 2nd, 3rd and 4th gears. this allows for a more durable transmission. |
| | #29 | |||
| RETIRED | Quote:
crower makes them for both t and n/a as well as non and vtec. so lets go there... b series VTEC t from crower (they have2) 63411T Stage 2 - Turbo special design. Short duration = low overlap, high lift for increased performance. Requires 84161 spring/retainer kit. Int-280 mid Exh-276 mid Int-230 mid Exh-226 mid Int-.465 mid Exh-.445 mid 63401T Stage 2 - Turbo special design. Short duration = low overlap, high lift for increased performance. Requires 68185 spring. Int-280 mid Exh-276 mid Int-230 mid Exh-226 mid Int-.465 mid Exh-.445 mid BOTH these cams have the same specs. non vtec t crower cam 62402T Stage 2 - Turbo/Super Charger specially designed specifically for forced induction applications. Features short duration, high lift for added cylinder pressure and good bottom end power. Requires kit 84162. 235 / 235 190 / 190 .469 / .469 now i know those numbers don't mean much... BUT the durations of the vtec cams are much larger- simple comparison. the lift of the non-vtec, 445/465 vs 469/469 turbo + lift = good turbo + duration = blow by and wasted power. | |||
| | #30 | |
| RETIRED | Quote:
i think that even though the synchros may be differernt, driver mashing comes into play on this as well. if you know how to drive and don't mis shift a lot, i think that that factor really doesn't play into durability. and for more info on the cmas i used- http://crower.com/cat/import/honda/camshafts.shtml | |
| | #32 |
| RETIRED | me and chet talked about this while we were going back and forth as well with some minor edits for space... hes passing out- but here's our convo that we had- it has a lot of good stuff in it as well. -------------------------------------------------- pissedoffsolwork (12:36:43 AM): refresh that thread we are going at it in :-) pissedoffsolwork (12:37:49 AM): :-) these are the type of threads i would like to have on the board all the time chethewitt (12:39:25 AM): reply pissedoffsolwork (12:45:55 AM): oh this is gonna be good :-) chethewitt (12:46:21 AM): you've already been owned chethewitt (12:46:26 AM): i'd quit while your'e ahead pissedoffsolwork (12:47:46 AM): no way man pissedoffsolwork (12:47:48 AM): i just owned you pissedoffsolwork (12:47:50 AM): refresh :-) pissedoffsolwork (12:47:53 AM): with REAL specs pissedoffsolwork (12:47:54 AM): hehe chethewitt (12:49:57 AM): i know toda doesn't make turbo cams pissedoffsolwork (12:50:02 AM): i know pissedoffsolwork (12:51:00 AM): who ever wins, really- no one will- i just like these topics- because it's based on fact- not opinion- yet it shows both sides of the wheel. pissedoffsolwork (12:51:10 AM): i dunno- like i said, i wish all our topics were like this chethewitt (12:57:00 AM): i'm tired chethewitt (12:57:06 AM): i'll respond in the morning pissedoffsolwork (12:57:50 AM): haha pissedoffsolwork (12:57:54 AM): you gotta think about it :-) pissedoffsolwork (12:58:05 AM): someone is getting owned :-) chethewitt (12:58:08 AM): i'm too tired to respond correctly pissedoffsolwork (12:58:10 AM): lol pissedoffsolwork (12:58:15 AM): im just busting your balls chethewitt (12:58:17 AM): and i want to ask cory about this also pissedoffsolwork (12:58:21 AM): but you see my points, right? pissedoffsolwork (12:58:24 AM): i think they are more than valid chethewitt (12:58:39 AM): yes, but with crower cams i want to see the power they make chethewitt (12:58:40 AM): throughout chethewitt (12:58:52 AM): with vtec, you can run two sets of lobes... pissedoffsolwork (12:58:56 AM): i wish they listed dynos too... its hard to comapre without it chethewitt (12:58:59 AM): that allows for more tuning chethewitt (12:59:06 AM): cory will know immediately pissedoffsolwork (12:59:08 AM): agreed- chethewitt (12:59:21 AM): which is why i have a hard time beliving pissedoffsolwork (12:59:21 AM): but, like you said, after 1st gear- you are 6-8k and thats about it chethewitt (12:59:35 AM): the crower cams aren't going to be effective down low, so now you're basically left with a setup chethewitt (12:59:44 AM): that is great up top, and has nothing down low pissedoffsolwork (1:00:05 AM): but with no crazy power down low- you can get a launch and not spin chethewitt (1:00:20 AM): you're spinning in circles pissedoffsolwork (1:00:21 AM): and then as you catch 5k or so- you start to pull the same as a vtec would chethewitt (1:00:23 AM): why not have an even power band chethewitt (1:00:32 AM): with vtec, thats what you can do chethewitt (1:00:35 AM): and set the vtec point chethewitt (1:00:38 AM): to best suit the setup chethewitt (1:00:41 AM): so its even power pissedoffsolwork (1:00:47 AM): an ls power band is very similar to a v8's as far as it's curve goes... pissedoffsolwork (1:00:53 AM): kinda sorta pissedoffsolwork (1:00:56 AM): its flatter chethewitt (1:01:00 AM): but there is a compromise chethewitt (1:01:08 AM): while you might* make better low/mid chethewitt (1:01:12 AM): the top end will suffer chethewitt (1:01:15 AM): and i don't see how this will change chethewitt (1:01:19 AM): without vtec pissedoffsolwork (1:01:23 AM): not if its the same cut as the cam on the vtec chethewitt (1:01:33 AM): but thats like pissedoffsolwork (1:01:37 AM): it will suffer a little down low, and then make similar power where it is chethewitt (1:01:39 AM): engaging vtec at 2k chethewitt (1:01:45 AM): i've done this chethewitt (1:01:47 AM): just to fuck around chethewitt (1:01:52 AM): and my car was dying chethewitt (1:01:54 AM): almost stalling pissedoffsolwork (1:01:58 AM): yeah pissedoffsolwork (1:02:06 AM): because the air/fuel is right for it either chethewitt (1:02:17 AM): partly yes pissedoffsolwork (1:02:17 AM): changing the lobe requires tuning - chethewitt (1:02:21 AM): but chethewitt (1:02:30 AM): everyone would engage vtec at 2k chethewitt (1:02:34 AM): if it were making more power pissedoffsolwork (1:02:39 AM): i agree- it doesn't pissedoffsolwork (1:02:51 AM): in fact, most bump it up as they get more built pissedoffsolwork (1:02:54 AM): and can rev higher chethewitt (1:02:58 AM): yes chethewitt (1:03:00 AM): exactly pissedoffsolwork (1:03:30 AM): but again, thats 1st gear. chethewitt (1:03:44 AM): but you still need to be able to drive the car chethewitt (1:03:47 AM): at normal rpm's pissedoffsolwork (1:03:52 AM): and with a turbo- and the lag it creates- the cam profile really doesn't play as much into it as it does when you are NA chethewitt (1:04:03 AM): won't you have more lag chethewitt (1:04:07 AM): because the car is making less power? chethewitt (1:04:18 AM): because the timing is basically fucked chethewitt (1:04:22 AM): if you use the same cut chethewitt (1:04:24 AM): as vtec chethewitt (1:04:27 AM): down low? pissedoffsolwork (1:04:36 AM): not necessarliy... lag is based on exhaust flow being low.. and hence, spinning the exhaust wheel slower chethewitt (1:05:20 AM): the more power the motor makes chethewitt (1:05:24 AM): the more exhaust it creates chethewitt (1:05:30 AM): and the faster the turbo will spool chethewitt (1:05:52 AM): hence small displacement motors being unable to spin big turbos chethewitt (1:05:57 AM): which equates to a lot of lag pissedoffsolwork (1:06:02 AM): see- thats another factor that we don't have any prrof on... just how MUCH exhaust flows out at any given rpm for a vtec vs a non vtec motor chethewitt (1:06:07 AM): why not put a t-88 on a b16a? chethewitt (1:06:18 AM): like i said, i will ask cory pissedoffsolwork (1:06:27 AM): here's the thing pissedoffsolwork (1:07:01 AM): honda motors, crave low pressure, but a lot of air mass. supras on the other hand crave both high pressure (30 psi and stuff) as well as the high air mass chethewitt (1:07:19 AM): ah chethewitt (1:07:20 AM): i'm tired chethewitt (1:07:24 AM): i can't think about this chethewitt (1:07:26 AM): anymore chethewitt (1:07:41 AM): i will come up with an appropriate response tomorrow pissedoffsolwork (1:07:45 AM): so a big turbo, boosting 10 psi, will create a lot of air mass. a small turbo, will have to boost much higher psi to create similar air mass lelves- and it will be feeding it the high pressure that they don't want pissedoffsolwork (1:08:10 AM): i think im going to copy/paste this convo into the post as well- we talked about a lot of good stuff in this pissedoffsolwork (1:09:12 AM): ok dude- I'll let you get some sleep :-) pissedoffsolwork (1:09:22 AM): always a pleasure to argue about cars over the internet pissedoffsolwork (1:09:23 AM): haha chethewitt (1:09:55 AM): ok chethewitt (1:09:58 AM): laterman pissedoffsolwork (1:10:00 AM): late --------------------------------------------------- so, there you have it... more stuff to follow |
| | #35 | |
| RETIRED | Quote:
Chet: 0 Brian: 0 | |
| | #36 |
| Senior Member | A little off topic, but after all thats been said, I think this is my new plan- 5-6 psi on some turbo, new goal- to break into the 13's, with no burnouts and soft launches, i think the differential will hold up for a while then after i get some loot, on to stage 2....built motor, quaifeLSD/ clutch capble of 300 whp, hondata, 15-18 psi, hoping for high 11's on that setup possibly new turbo new question- since i will only be running 5-6 psi, would it be a better idea to get a smaller turbo, then when the time comes sell that and get a bigger one?
__________________ <a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a> I will paypal $8 to the first 3 people to complete the offer, PM me if interested. |
| | #37 | |
| Member | Quote:
-x | |
| | #38 | |
| RETIRED | Quote:
bigger turbo- making more compressed air at less psi is what hondas love. | |
| | #39 |
| Senior Member | first and foremost, i am god damn impressed with this thread, i'm glad i signed up here.. it's amazing not to see a flame war going on, finally some sensible people... pissedoffsol- i'm pretty inquiried about your airmass/pressure theory, but trying to visualize this shit on a few hours of sleep not to mention not any science classes at all in the last 3 years is driving me batshit, are you refferring to airmass as the total amount of air in the cylnder and obviously we know what pressure is... but wouldn't mass and pressure increase directly and proportionally with each other?? i'm not saying your wrong at all because i have a feeling there's somthing i'm not grasping here.. so saying your correct that honda motors love low boost and more airmass why aren't we running t78's at 5psi ... (bring on the lag arguement) and yes i know i should probally be posting when my mind is completely with me because i know i'm gonna get owned soon, but i'm not saying i'm right with anything i say, i'm trying to see if we can be on the same wave length. |
| | #40 |
| Senior Member | ok before one of you owned me about the relationship to mass and pressure theories, i had my dad do it... now it clicks he brought up the v1p1=v2p2 forumula i havn't seen in years.l in a nutshell, in case it didn't click to anybody else like it did to me earlier a larger housing takes less psi to force the same mass of air, as where a smaller housing would take more pressure to push the same amount of air because for instance look at v1 as being a larger volume turbo and v2 as being yes smaller..... i'm gonna just use generic numbers anyways so fuck it if v1 had a volume of 100 and pressure of 20 and v2 had a volume of 50 (v1 X p1) 2000 cfm ------------ = ---------- v2 50 psi so the pressure of 2 would be 40 psi |
| | #45 |
| Senior Member | also, the rod/stroke ratio with b18b's is awful. its not meant for high rpm's, which means it will take a built motor to rev above 7k consistently. basically, b18b blocks are less efficient at higher rpm's and cause more heat and less power. this is a problem a lot of ls/vtec guys have when consistently revving unbuilt bottom ends above 7-8k. |
| | #46 | |
| | #48 | |
| | #49 |
| Member | The LS. Lower CR, no vtec (so no long duration lobes to screw with the turbo), etc. I think the argument originally started over which transmission was better for boost, the ls or gsr. There's no question that the ls ENGINE is better for boost. If you want to rev-high, then the gsr is better. Personally i'd rather have torque on tap. |
| | #50 | |
fact: gsr motors make more torque compared to ls motors in the lower rpm's and more power up top. so again, you're wrong. i'm not sure who spreads this misinformation, but its simply not true, and if you need anymore proof look at the yellow crx lining up vs lisa kubo. not only is he running a turbo gsr setup, but another guy i know has put down over 500hp and over 350 torque with a turbo nitrous setup. ls motors wouldn't touch these numbers on similar setups. so basically, the ls motor needs to be built that much more to achieve the same numbers... its like starting with a weaker platform to achieve the same goals...and in the end its not cheaper and not more efficient.
__________________ <a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> | |
| Forza Final Car List | Prowler | Members' Lounge | 11 | 01-17-2005 11:20 PM |
| ::Testing Waters:: '95 Turbo d16z6 175WHP @5000RPM | steeze | Parts: For Sale/Trade/Wanted | 6 | 01-09-2005 05:12 AM |
| turbo parts | yellow21 | Parts: For Sale/Trade/Wanted | 0 | 12-16-2004 10:40 PM |
| HKS Super Turbo Kit | truoss | Forced Induction | 7 | 11-28-2004 03:20 PM |
| I found best turbo shop around! | aCCoRD-TyPe-R | Forced Induction | 9 | 12-12-2003 01:58 AM |
