Whats Wrong With This Ghetto Turbo Setup?
Closed Thread
Old 08-25-2004, 12:54 AM   #1
Rep Power: 15 hondamidnighter is off the scale
Send a message via Yahoo to hondamidnighter
Arrow
As i posted earlier on about a Teo4h turbo my friend put on his del sol leaking oil, well its about that setup. But let me start first how he got the idea of ghetto turbochargin his del sol.
It all started with his friend saying that he had installed turbo in about 4 different cars and had been success and shit. Well he brainwashed my friend and started telling him things what to buy. He had a Teo4h turbo already lying around so he used that because even tho the wastegate was set a 5.5 he cant go beyond 6psi on a fmu setup. Then a 12:1 vortech fmu, eclipse intercooler(modded to fmic), flexible ghetto charge pipes, flexible exhaust downpipe, hose lines, check valves, and miscelleneous crap ect. So okay the way the guy installed the turbo was buy using the flexible pipe off the cat from the exhaust manifold and into the turbo.
After that he ran flexible pipe out of the compressor housing and into the intercooler which is a 2" pipe. Which I think is too big for the pressure too build.
Well as ive seen he ran everything okay as far as ive seen other setups. Had a few problems with the oil line but got fixed and no more oil leaked.
But here is the problem, my friend and his "friend" are pissed because the blow off valve is not loud until past 4000 rpm. They said that its probably the boost is not building up. So they ran without the wastgate opening and still didn't get high boost. They checked for leaks and didnt find any. The turbo spools and everything but well Teo4h turbos aint are really good neither. We thought it was the exhaust but he has a 2.5 cat.
What i think is that he shouldnt run his turbo like on the example on top. Or his charge pipes are to big for 5.5. But how can the turbo not make more psi even with the wastegate not opening?? <_<
BOOST COMING SOON....IN SOL THEATRES NEAR YOU!!!!
hondamidnighter is offline
Old 08-25-2004, 10:09 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the turbo is internally gated. how did you take it off?
pissedoffsol is offline
Old 08-25-2004, 05:32 PM   #3
No he disconnected the line from the turbo to the wastegate allowing the wastegate not to open at all.
Old 08-25-2004, 05:35 PM   #4
RETIRED
well, id say get a boost gauge- and see where it makes boost.
my turbo blows off under 0 psi (in vacuum) just due to the utter size of air that it pushes out.
Old 08-25-2004, 06:22 PM   #5
Does 2-3 pounds sound good ? Its crazy how the turbo is creating 2-3 pounds when you hear it spooling.
Old 08-25-2004, 07:17 PM   #6
RETIRED
honeslty, it sounds like you have some serious bosot leaks.
check ALL of your piping.
those ghetto bend-a-pipe things im sure leak
Old 08-25-2004, 09:00 PM   #7
Rep Power: 14 [Freemantle] is off the scale
How is your engine performing N/A? Are all your cylinders firing?
Buy a spray bottle and fill it with water. Mist the air around your piping, IM, ect and see if it gets blown around. The fact that you are making 2ish psi at full spool suggests that the work is being done, but lost somwhere along the way. This would also suggest why you didn't gain any boost when you unplugged the wastegate.
WTB: 88-91 CRX of any trim level -- central Florida area --
[Freemantle] is offline
Old 08-25-2004, 09:55 PM   #8
Arrow
The engine a a d15b7 or b8 not to sure. But if is a d15b8 could it be the engine? Because d15b7 pull more hp than the b8 does. The d15b8 has 8 valves and the b7 has 16valves. Put his engine is in pretty good shape. My friend had just emergency recently swap the engine because he messup the old one.(zc) Yesterday he came and my dad told me to use the spray water and soap method. But no leaks on the flexible charge pipes. Nor where the rubber connectors meet and join other tubes.
But what i think is that the there is to much charge pipe for that poor turbo. Its trying to blow boost on 2" , 10 feet long charge pipes including the intercooler.
Old 08-25-2004, 10:33 PM   #9
RETIRED
10' of charge pipe!?!?! how the hell did your route it!
6-ish is normal.
figure, its like 3-ish for a CAI 2' for the ic and 2 for the hot side. where the other 3 feet coming frmo?
Old 08-25-2004, 11:03 PM   #10
See the way he ran the turbo was by using flexible pipe tubing from the cat all the way to where the OEM Air filter box use to be. Then from there he ran the hot side of turbo right pass by the cv axle then straight to the intercooler then from the intercooler through where the water tank use to be all the way throught the back of the block and into the intake mani. So making the waste exhaust go through were the existing oem intake pipe use to go.
One freakin crazy setup just to keep the A/C system.
Old 08-25-2004, 11:04 PM   #11
RETIRED
how the....
its an internally gated turbo... what part of exhaust gas does he even need to worry about?
Old 08-25-2004, 11:08 PM   #12
Well he is trying to replicate a cheap kind of lovefab manifold keep a/c shit.
Old 08-25-2004, 11:11 PM   #13
RETIRED
but that has nothing to do with routing wastegate gasses.....
Old 08-25-2004, 11:20 PM   #14
Well tomorrow im changin his fukin mind of his of keepin his A/C. Im going to tell him to do it the usual way. Right off the freakin manifold.
Old 08-25-2004, 11:29 PM   #15
Rep Power: 59 hcivic.com is on a distinguished road
wtf i can't understand this
hcivic.com is offline
Old 08-26-2004, 09:29 AM   #16
RETIRED
right off the manifold? wtf dude..
heres how it should be.
motor.head -> turbo mani -> turbo
from here, we split 2 ways.
-wastegate gases, downpipe gases
wastegate gases eventually get to the downpipe
and exit out the exahsut.
now, on the other half of the turbo, you have the hot pipe to I/C , and the charge pipe up to the throttle body on the other side.
its very simple.
Old 08-28-2004, 07:13 PM   #17
OOOOOOOH! I think I get it!
It's like the sidewinders? His battery in the trunk and everything?
I think he was running the turbo on the side of the car (where your factory aribox would be), but 2 flanges were welded on the end of some shitty, shitty bend-a-pipe so that it could be hooked up to the hotside and the manifold flange. Then some more bend-a-pipe was run from the DP flange to the cat.
Whoever would do this to their car deserves to have it stolen from them. That is completely stupid on so many grounds.
Old 08-29-2004, 01:20 AM   #18
Yeah just Like that Sidewinder manifold. But on Del sols, you dont have to remove the battery. And well with all that bend a charge pipe i think the turbo cant take it to charge all them up! But now i change his mind and he is going to buy a turbo manifold to keep the A/C.
Old 04-12-2007, 06:03 AM   #19
Last samurai
Ride:  honda
Rep Power: 0 MR Miyagie is on a distinguished road
myspace
can i see some pics of the motor
Who dat making that funky noise?
MR Miyagie is offline
Old 08-09-2008, 05:44 PM   #20
Rep Power: 0 92 d15b7 CX mike is on a distinguished road
Default too much pipeing
you have way too much pipeing, so the compressor side of the turbo is only compressing the air inbetween the turbo and the intake, thats why your only getting 2-3 psi. I'm assuming the turbo is in good condition. I'll use this as an example, if you have a 20 gallon compressor tank vs. a 5 gallon compressor tank which will take longer to compress the air? its not rocket science. Good Luck
92 d15b7 CX mike is offline
Old 08-09-2008, 05:45 PM   #21
ps . im drunk
Old 08-09-2008, 08:16 PM   #22
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 221 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Your a retard, this thread is 4 years old.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
efhondakid is offline
Old 08-09-2008, 10:17 PM   #23
Hands Off my Balls
NWDRVRBWE's Avatar
Rep Power: 16 NWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of light
Send a message via AIM to NWDRVRBWE myspace
you should have thrashed the noob dude.....
Rep's a B****, Why have any?
NWDRVR
NWDRVRBWE is offline
Old 08-09-2008, 10:20 PM   #24
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
fail
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline
Closed Thread
