Go Back   HondaSwap Forums > Technical Articles and Reference > General Tech Articles
How To: Change a Head Gasket. -LOTS of pics-
Old 01-20-2007, 02:36 PM   #26
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Originally Posted by welfare View Post
You actually missed one very important step. . .
once you drain the coolant there is still some in the block so when you take the head off it goes everyehere (like in your pics)
Not only does it go in the clyinders, but it also goes in the holes in the bolck where the headbolts go.
Also, like remedy said coating the bolts in oil or some sort of lubricant is reccomended due to correct torque measurements. It takes more torque to tighten a bolt that has no lube as opposed to a bolt that does.
Also, it is recommended that you replace the headbolts after you remove them, but I have also seen the re-used with no problems.vv
Excellent writeup nonetheless
Thanks for your imput bro!
In that case I guess I got off easy, because I didn't have any problems with coolant in the bolt holes, and very little on the pistons(which were all cleaned out btw, I just didn't show the reinstall.
I did soak them in oil. didn't you see?
And lastly,
Originally Posted by Calesta
Honda DOES tell you to replace the bolts when you remove them, but many people reuse them without a problem.
Thanks for re-enforcing that point!
Again, I appreciate your imput. every little tid-bit helps
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 12:02 PM   #27
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
no posts in a while, time to archive this in the general tech articles
Thanks Andrew
HTML code is On
ls vtec head gasket lsvteccrx Engine Building 2 09-20-2009 05:56 PM
Head Gasket Question??? accord1087 General Tech and Maintenance 1 07-06-2006 12:48 AM
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 05:48 AM
What else should I replace if doing head gasket? ssl2k Engine Building 6 04-14-2004 12:30 PM
