Go Back   HondaSwap Forums > Technical Articles and Reference > General Tech Articles
How Do I Reset The Srs Light?
Old 01-05-2003, 11:03 AM   #1
the OG
wildbillhatchbac's Avatar
Ride:  97 bmw m328, 08 yamaha r6s, 94 suzuki dr350, 73 honda cb350 cafe racer
Rep Power: 23 wildbillhatchbac will become famous soon enoughwildbillhatchbac will become famous soon enough
Send a message via AIM to wildbillhatchbac myspace
Reseting the ECU won't do anything for you. . . you can read the code from the same ECU service connector (passenger side under dash) however to reset the light follow these steps.
1. turn ignition switch off, remove ECU service connector
2. connect (jump) the MES connector (this is 2 pin yellow connector wrapped in yellow plugged in the front of the underdash fuse box)
3. turn ignition switch on
4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out.
5. the SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
6. the SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
7. the SRS light will blink to times indicating the memory is reset.
Hi
wildbillhatchbac is offline   Reply With Quote
Old 01-08-2004, 12:07 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
More information can be found here:
http://www.hondapitstop.com/accord/t...1/SRS/srs.html
HTML code is On
Forum Jump
How many forum posters does it take..... pissedoffsol Members' Lounge 51 12-01-2007 12:32 AM
how do i reset the maintence required light????? b18vtecrx General Tech and Maintenance 11 03-08-2007 12:47 PM
Oil Light...weird...help? Magik General Tech and Maintenance 8 03-19-2004 02:00 PM
Steering Wheels and Air Bag SRS Light HONDAPITSTOP General Tech and Maintenance 3 11-06-2003 07:10 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
