Go Back   HondaSwap Forums > Technical Articles and Reference > General Tech Articles
What Is The R/s Ratio?
Old 02-02-2003, 10:33 PM   #1
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Think about what R/S means for a second. Rod length / Stroke length. All it says is that ideally your rods are 1.75 times the length of you stroke. Now if you stop and consider why that ratio is so "good". The longer your rods are compared to you stroke the smaller the angles are between vertical and rod position as the pistons travels up and down. Envision a cross section of an inline reciprocating piston engine. As the piston starts to climb from BDC the rod forms an angle with vertical at the wrist pin. If you have taken any physics this is pretty basic. Think of a force diagram illustrating the forces acting on the wrist pin ( for simplicity sake assume that the piston and wristpin are one unit). The larger the angle between vertical and the rod, the larger the sine of that angle, and the larger the horizontal component of the force applied to the wrist pin (meaning more side loading on the piston and cylinder wall causing ovaling of the cylinders, increased piston wear, etc.).
1.75:1 is "perfect" because it is a good comprimise. The steeper rod angles make for more torque and longer rods put less pressure on the sidewalls. 1.75:1 is the optimization of these two factors (so you get the most torque with the least sidewall loading). Most engines run a an RS ratio of less than 1.75:1.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 02-04-2003, 12:21 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Just for reference... stock rod/stroke ratios are as follows, rounded to the nearest thousandth:
B16A / B16B = 134.36 / 77.0 = 1.745
B17A = ? / 81.4 = ?
B18A / B18B / B20B / B20Z = 137.0 / 89.0 = 1.539
B18C = 137.9 / 87.2 = 1.581
B20A = ? / 95 = ?
If you want more precise ratios, calculate them yourself. If anyone can give proof of what the B17A and B20A rod lengths are, please PM me and let me know. You can use these numbers to make your own crank/rod combos to see what kind of ratios you'll get with different builds.
HTML code is On
Quicker ratio steering rack for EG? stmotorsports Wheels / Suspension / Tires / Brakes 6 06-04-2004 11:53 AM
Automotive Formulas pissedoffsol Reference Materials 0 03-01-2004 07:06 AM
what ratio pistons??? bvtec Forced Induction 7 01-16-2004 06:33 AM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
compression ratio? kmcCR-Vtec HYBRID -> EG-EK / DC 2 12-23-2002 12:58 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
