5$ paypal for anyone that can help solve this prob
Old 12-15-2004, 03:08 AM   #1
Rep Power: 19 Jdubspeeds is off the scale
Send a message via AIM to Jdubspeeds
The check engine light inst coming on when you turn the key to on. and the ecu does not blink to show that it is working? I replaced the main relay and tested the distributor and they are both fine. What am I missing. Why wont this ecu turn on? I have tried another of my ecus and it wont turn on eithier.
<u>I own </u>
[b]2000 Gray Audi TT Quattro
2004 White/Blue GSXR 750
1981 Vw Caddy
1986 Yugo (yes yugo)
Jdubspeeds is offline   Reply With Quote
Old 12-15-2004, 04:44 AM   #2
Rep Power: 59 hcivic.com is on a distinguished road
im asuming you check than main battery fuse and others
hcivic.com is offline   Reply With Quote
Old 12-15-2004, 12:25 PM   #3
Originally posted by pheonixb16aguy+Dec 15 2004, 04:43 AM--><div class='quotetop'>QUOTE(pheonixb16ag uy @ Dec 15 2004, 04:43 AM)</div><div class='quotemain'><!--QuoteBegin-Jdubspeeds@Dec 15 2004, 03:08 AM
The check engine light inst coming on when you turn the key to on.* and the ecu does not blink to show that it is working?* I replaced the main relay and tested the distributor and they are both fine.* What am I missing.* Why wont this ecu turn on? I have tried another of my ecus and it wont turn on eithier.
where the ecu grounds out on the thermostat bolt... is that hooked up ??
is ur battery fried ?? <_<
[/b][/quote]
I looked and didnt see any grounds near that the thermostat
<u>I own </u>
1981 Vw Caddy
Old 12-15-2004, 12:25 PM   #4
yeah i checked the fuses
<u>I own </u>
1981 Vw Caddy
Old 12-15-2004, 01:56 PM   #5
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
check the bulb on the back of the cluster. check to see if its there first. if its there, then try another bulb.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 12-15-2004, 03:32 PM   #6
Rep Power: 16 Judo_boy_48 is off the scale
Send a message via AIM to Judo_boy_48 Send a message via MSN to Judo_boy_48
I think he meant his ECU isn't working. Not the bulb.
Maybe use a multimeter to see if your getting any voltage to the ECU?
90' CRX Si
05' Chevy Colorado Xtreme
08' Chevy Trailblazer SS
Step to a vette...
http://www.youtube.com/watch?v=K6e_zcp-W2g
Judo_boy_48 is offline   Reply With Quote
Old 12-16-2004, 10:56 PM   #7
friz's Avatar
Rep Power: 19 friz is an unknown quantity at this point
Originally posted by Jdubspeeds+Dec 15 2004, 11:25 AM--><div class='quotetop'>QUOTE(Jdubspeeds @ Dec 15 2004, 11:25 AM)</div><div class='quotemain'>
[/b][/quote]
The grounds at the engine and the strap from the engine to the chassis is very important. I would look in this direction. Power to the unit is not important if you don't have a ground path.
friz is offline   Reply With Quote
