87 si rex not wanting to start
Old 10-03-2006, 05:20 PM   #1
Periculum is off the scale
Default 87 si rex not wanting to start
hey guys, this question is for a friend of mine whose 87 CRX SI does not want to start on certain occasions. It seems to be heat related.
The battery has been checked and load tested: passed.
Fuel pump and filter both replaced
spark plugs, distributor, ignition coil all recently (<5kmi) replaced
he says there was no oil on any plugs when he puleed them a few days ago to check.
He also has issues with a minor bit of stalling out just after starting and a misfire (jerk as he describes it) only after he passes 60 MPH.
After everything he has done im beggining to think injectors or fuel pressure reg. I dont know how to check fuel pressure so I havent been able to tell him yet. Any ideas would be a great help to a man about to shoot a rex
91 CRX HF-ZC motor and tranny swapped
-This is what the HF should have been, just a low redline.....
"My Car should Qualify as an ULEV.
An Ultra Low Expectations Vehicle" -no more that motor is outta here!
Periculum is offline   Reply With Quote
Old 10-03-2006, 06:00 PM   #2
jlicrx's Avatar
jlicrx has a brilliant future
sounds like it might be the Main Relay
Old 10-03-2006, 06:25 PM   #3
dont relays just stop working, like fuses, or do they die out?
Old 10-03-2006, 06:43 PM   #4
also the starting problem seems to get worse the more times he tries to start it. If the car stalls and he tries to start it right after, it will stall shortly after that, then wont even start the next time around.
1994 EX Coupe Wont Start - PLEASE READ HELP ME!! The_MATRIX General Tech and Maintenance 6 01-02-2007 10:28 PM
90 Accord w/ M/T won't start jeeva86 ECU's, Electronics, and Tuning 0 08-13-2005 11:36 PM
this weeks amazon.com deals pissedoffsol Members' Lounge 8 06-30-2005 05:25 AM
deals at Amazon.com pissedoffsol Members' Lounge 2 06-22-2005 11:33 PM
Car wont Start i need help! Masta General Tech and Maintenance 16 10-10-2003 10:26 AM
