Can I use the FD gear out of any 92-93 Integra manual transmission in my 92 GS-R transmission? The FD ratio is the same. What is the part called that drives the FD gear, I forget. Is that compatible too?
When I got my LSD switched into my new transmission I'm pretty sure the tranny shop did not shim the diff correctly because it has been making noise and it has a lot of freeplay. It's been like this for a year, I was stupid not to bring it back right away because it wasn't apparent right away because it was a new transmission and I wasn't sure. I'm guessing since it's been like this for a year the gear is probably damaged and needs to be replaced or it'll still have freeplay when shimmed correctly. Last edited by ED9man; 06-22-2006 at 04:01 PM. |
#4 | |
Transmission Ratio (:1) RS - LS - GS (manual) 1st 3.230 2nd 1.900 3rd 1.269 4th 0.966 5th 0.742 Reverse 3.000 Final Drive 4.266 GS-R 1st 3.307 2nd 2.105 3rd 1.458 4th 1.107 5th 0.875 Reverse 3.000 Final Drive 4.400 from g2ic.com check with acuraparts247.com to figure out part numbers for the parts your asking about __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#6 | |
| zc swap into 85 crx? | devnjeff | HYBRID -> ED-EF / DA | 4 | 07-10-2005 11:09 PM |
| B-series Transmission Guide | pissedoffsol | Swap Articles | 1 | 06-01-2004 05:46 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
