99/00 Car is Dead
Old 09-01-2004, 04:08 PM   #1
Rep Power: 18 khai_tuan_nguyen is off the scale
My friend has a bone stock 99/00 civic 4 dr LX (economy car). She has had the car for a few years. It has 50,000 miles. All of a sudden this morning it didn't start. When she turned the key it cranked but didn't turn over. Her radio comes on like normal. Any ideas what it could be? Or what it is not? What can I check?
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a>
khai_tuan_nguyen is offline   Reply With Quote
Old 09-01-2004, 04:14 PM   #2
allbottledup's Avatar
Ride:  95 Honda Civic EX
Rep Power: 27 allbottledup is an unknown quantity at this point
Send a message via AIM to allbottledup Send a message via MSN to allbottledup Send a message via Yahoo to allbottledup myspace
altenator, battery might not have enough volts, a relay could be bad. Start at the battery and work your way from there.
allbottledup is offline   Reply With Quote
Old 09-01-2004, 04:17 PM   #3
Could it be a starter
Old 09-01-2004, 06:19 PM   #4
Ride:  Boosted B16 in ej1
Rep Power: 26 driverunknown is on a distinguished road
Send a message via AIM to driverunknown
If it cranks like it wants to start (powerful crank), THen it is not the battery or starter. DO you hear the fuel pump when the key is turned to the on position, just before you start cranking? IF you can't, then your relay or fuel pump is bad. If you can, then check your distributor by doing the cap, rotor and wire replacement. If not that, then you might want to check your coil.
The swap is completed. Dented oil pans will kill vtec.
Now boosted!
Vouches:
Wanderinman
driverunknown is offline   Reply With Quote
Old 09-02-2004, 07:34 PM   #5
Ok the car starts now, it just takes one or two cranks longer. What could it be? It drives fine with no loss of power. Could it be alternator?
Khai
