| | LinkBack | Thread Tools |
| | #2 |
| Senior Member Join Date: Jul 2003 Location: buck teeth and government checks, PA
Rep Power: 51 | It's pretty easy. Although your car is OBD2b and is best checked with an OBD2 diagnostic "scan tool" you can check the codes yourself easily and even see what they mean. Look on your passenger side under dash area near where your ECU is located. You should look and feel around for a two-prong plug that will more than likely be green or blue or even brown. Take a piece of wire or a bent paper clip and touch one side each of your wire or paperclip to each of the pins on that plug. This will complete the "loop" and allow you to check your codes. Turn your key into the "on" position just before the car actually cranks, and count the flashing check engine lights. Long flashes mean 10, while short flashes mean 1. So if you had 2 long blinks quicly follwed by 3 short flashes you'd have a code 23. You may se more than one code, so be sure to count the flashes until you see the same code repeated again to be sure you got all the codes. The codes are as follows: Code Meaning 1 O2A - Oxygen sensor #1 2 O2B - Oxygen sensor #2 3 MAP - manifold absolute pressure sensor 4 CKP - crank position sensor 5 MAP - manifold absolute pressure sensor 6 ECT - water temperature sensor 7 TPS - throttle position sensor 8 TDC - top dead centre sensor 9 CYP - cylinder sensor 10 IAT - intake air temperature sensor 12 EGR - exhaust gas recirculation lift valve 13 BARO - atmospheric pressure sensor 14 IAC (EACV) - idle air control valve 15 Ignition output signal 16 Fuel injectors 17 VSS - speed sensor 19 Automatic transmission lockup control valve 20 Electrical load detector 21 VTEC spool solenoid valve 22 VTEC pressure valve 23 Knock sensor 30 Automatic transmission A signal 31 Automatic transmission B signal 41 Primary oxygen sensor heater 43 Fuel supply system 45 Fuel system too rich or lean 48 LAF - lean air fuel sensor 54 CKF - crank fluctuation sensor 58 TDC sensor #2 61 Primary oxygen sensor 63 Secondary oxygen sensor 65 Secondary oxygen sensor heater Also there are more in the 70's I *think* and they mean random misfires, which usually means you need spark plugs and/or wires or a general tune-up.
__________________ http://www.midwesthybrid.com |
| | #3 |
| Junior Member | "Look on your passenger side under dash area near where your ECU is located. You should look and feel around for a two-prong plug that will more than likely be green or blue or even brown." Does the plug resemble a over sized phone jack with 2 outlets (with one of the outlets occupied by a plug) ? I found a green plug, like I just described, and a flat brown one. Thanks |
