About changing fuel injectors
Old 10-18-2003, 10:27 AM   #1
HondaScythe is off the scale
Hello friends.
Can't make long posts, my network doesn't let me gotta fix that.
Ok, I have a 1995 Honda Accord LX, I got it a year ago it's stock all the way, F22B2, and it needs maintenance here and there. I thought instead of just servicing the car, why not UPGRADE it along the way?
So lately I've heard pinging, and i had it checked out, I was told my fuel injectors are dirty. It's gotten real bad when I accelerate, the pinging. I know other steps should be taken before switching fuel injectors, but because I need them cleaned now, I'm thinking I can just change them for new ones now. The stock fuel injectors on my car are 235cc I believe. I'm looking at 255cc injectors, or a bit larger if it's safe. Will this have negative effects on the way my car runs? Putting high-flow fuel injectors in while everything else is stock? (besides changing gas mileage a bit, i know that)
Thanks!
HondaScythe is offline   Reply With Quote
Old 10-18-2003, 10:28 AM   #2
I'd like to say that this is a pretty cool Honda board, usually Honda boards I've seen are full of the kind of people that give the company a bad image sometimes. You know who i mean. The kind that type in caps all the time, and trashtalk, and have less education than my cat's litter box.
Old 10-19-2003, 11:13 PM   #3
WRX Sellout
Ride:  2002 WRB Impreza WRX
dohcvtec_accord is an unknown quantity at this point
Why use larger injectors, unless you're planning on dumping thousands of dollars into that engine with a turbo or all-motor application? Just get some quality fuel injector cleaner and run that through there, or pay $30 to have them cleaned.
Drag kit install manual pissedoffsol Forced Induction 0 07-17-2004 11:37 PM
Fuel system Sed8ed Engine Building 2 05-26-2004 12:05 PM
fuel injectors darwins_vtech General Tech and Maintenance 2 01-16-2004 06:06 AM
Fuel Injectors???? gocivicls Engine Building 4 08-14-2003 05:48 PM
High Flow Fuel Filter? Injectors Clogged? importimage General Tech and Maintenance 0 05-17-2003 02:56 PM
