Acceleration Issue
Old 04-29-2008, 10:23 PM   #26
I dream of BOOST
Project"DELSolDad"'s Avatar
Ride:  93 Deli
Rep Power: 4 Project"DELSolDad" is on a distinguished road
Its not the heat shield on the cat, I checked that first, the rattle was coming from the inner tube inside the resonator pipe, it must have seperated..
Project"DELSolDad" is offline   Reply With Quote
Old 04-29-2008, 10:27 PM   #27
I dream of BOOST
Ride:  93 Deli
Not yet i hope this weekend the weather clears up so i can check.... no garage
And yes i can make a short video with my dvd cam I'll load it to my comp and get it to you somehow, I'll work on it tomorrow if i get out of work on time..
Old 04-30-2008, 12:27 AM   #28
Blinker Fluid Specialist
Ride:  95 delsol SI
Rep Power: 8 delsol88 is on a distinguished road
myspace
Originally Posted by YBLEGAL View Post
what? seriously? ...
vtec and clutch fluid have nothing to do in comon. unless your not closing the lid on your clutch fluid resiviour. wowwwww you've got to be kidding me.
that was the same thing i was thinking
delsol88 is offline   Reply With Quote
Old 04-30-2008, 02:29 AM   #29
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
alrighty. if you cant figure the video out, computers are my thing... lmk
i wanna see this. i've always thought about what your describing. like the pressure in the cylinder isnt enough to over come gravity. but i always thought as long as the engine is moving, it must not stall. so ya, i'm curious!
Old 04-30-2008, 02:30 AM   #30
YBLEGAL's Avatar
myspace
Old 05-01-2008, 02:55 PM   #31
I dream of BOOST
Ride:  93 Deli
sorry i didnt get the video to you yet, last two days ive been in pain, i need two root canals and i havnt moved the pain killers they gave me arent even helping me.. but i didnt forget so i'll hope get it to you by monday, sorry...
Old 05-01-2008, 03:43 PM   #32
YBLEGAL's Avatar
myspace
hey not a problem for me. i'll be lurkin...
whenever. i'm sure u want ur car fixed!
Old 05-01-2008, 09:02 PM   #33
I dream of BOOST
Ride:  93 Deli
These are 3 Vids I uploaded today, they are not great examples, for some reason today it decided not to act up on me
Old 05-01-2008, 09:19 PM   #34
YBLEGAL's Avatar
myspace
well since it does it only some of the time, it might be electrical. do you have a multimeter? you should check the voltage on the throttle position sensor (tps) to make sure it climbs smoothly. does it do it at full throttle? sounded like u were flooring it. maybe it will do it more often at part throttle? or, try starting in second gear (or short shift first gear), and accelerate hard in high gear, starting low in the rpm band. if you see what i'm saying. it will put more 'stress' on the motor, for say. see if it does it then.
Old 05-07-2008, 05:38 PM   #35
I dream of BOOST
Ride:  93 Deli
Old 05-14-2008, 01:59 PM   #36
Rep Power: 7 crash lander is on a distinguished road
my cars seemed like they had "vtec" to the problem was piston ring failure. When enough oil got into the cylinder it would kick like vtec at around 4-4.5K
crash lander is offline   Reply With Quote
engine reving issue iceberg65 ECU's, Electronics, and Tuning 5 01-14-2008 05:42 PM
clutch issue turbowagon92 General Tech and Maintenance 6 12-13-2007 12:10 AM
Fuel Regulator issue? SmoothRigoletto Accord 2 12-12-2007 12:36 AM
H22 Slow Acceleration Naz Accord 10 03-12-2007 01:06 PM
Need Help!!! Computer Ecu Issue 530kingteg Integra 1 12-21-2006 01:43 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
