acura integra manual transmission fluid
Old 10-13-2009, 02:18 PM   #1
Greenhorn
Ride:  secret
Rep Power: 0 slowboyy is on a distinguished road
Exclamation acura integra manual transmission fluid
my buddy told me i had to go to acura and get 3qts of manul trans fluid is this true or can i buy some from a local parts store(1997 acura integra ls)
slowboyy is offline   Reply With Quote
Old 10-13-2009, 05:24 PM   #2
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
personally i would never use the cheap stuff in my transmission
mdpsEG is online now   Reply With Quote
Old 10-13-2009, 05:48 PM   #3
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
Honda MTF is the shit. don't use anything else.
it's really not that expensive either
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old 10-13-2009, 11:08 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Disagree... sort of. Use GM synchromesh transmission fluid with friction modifier. Awesome stuff in Honda transmissions, but it will cost you twice as much as Honda MTF. You should only need 2 quarts too. If in doubt, look it up in your owner's manual.
On the other hand, if you aren't having any problems with your transmission now, don't switch from the MTF if you're not sure about going to the synchromesh. As a data point, I'll just tell you that I don't buy MTF at all.
Old 10-14-2009, 12:31 AM   #5
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
Ive heard great things about sycromesh....we use in our cars.
D15Beater is offline   Reply With Quote
Old 10-14-2009, 07:18 AM   #6
Rep Power: 14 78civic will become famous soon enough
I've been using Amsoil 0w20or30 (full synthetic motor oil) in mine for over 10yrs and only change it around every 5 or so.. It's usually 3-5x the change interval of petrolium base.
Actually My 92 accord had 111k on it when bought, It's now around 190 and only changed it once in 7yrs, and still shifting wonderful. My other cars usually get sold before I change it out.
E
"If you can read, thank a teacher"
"If you can read it in English, thank a VET"
78civic is offline   Reply With Quote
Old 10-17-2009, 04:20 PM   #7
Calesta's Avatar
Ride:  2003 S2000
Very nice. I change out my GM synchromesh every 15-20k miles. It's probably more often than needed, but that interval has always worked for me.
Old 10-20-2009, 08:33 PM   #8
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
my sudgestion is royal purple syncromax or GM syncro mesh. On a side note this is a trick that i have learned over the years that will help keep your trans alive.
Drain and fill per the normal procedure then install the plug once its full remove vent cap and add 1/2 qt more thru the vent hole. This will raise the fluid level up higher providing more lube to 4th and 5th gears and most importantly keep the Input bearing lubed and help keep it from failing which is a very comon problem in a honda transmission.
When ever i build a performance transmission for some one i actually weld in a new fill plug at the fluid level that i prefer and this seams to keep them alive much longet in high hp cars so it has to help with your DD
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 10-21-2009, 12:58 PM   #9
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
+1 for GM Synchromesh. I use it. It works excellent.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
transmission fluid fosach1 Civic and del Sol - EG and EK 1 11-17-2008 04:47 PM
Manual Transmission Fluid awptickes General Tech and Maintenance 22 11-12-2007 02:04 PM
fluid for my transmission 90htchbck General Tech and Maintenance 19 10-29-2007 01:49 AM
what transmission fluid??? 90htchbck HYBRID -> EG-EK / DC 7 05-22-2007 03:12 AM
Transmission Fluid JDMPlaya General Tech and Maintenance 5 05-22-2004 05:52 PM
