When I pull b18b engine I need to do the timing belt. I was going to replace the water pump and the oil pump for good measure for my turbo project. Should I use LS pumps or should replace them with something else. If so what timing belt would I use. I am only going to consider Honda OEM parts.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
my name is Dale
just do the oem timing belt kit. and a obd2 gsr/type r oil pump.
03 mustang mach1, procharged, built motor, 6sp swap, built rear. 525whp @9psi 00 cbr 929rr 420 conversion -1 +2 |
What would recommend for a water pump?
#5 |
thistownsucks...
remember if you use the gsr/type r water pump/oil punp, you also need to use the timing belt from the same. The LS belt is different and will not work.
id rather have a hondata and a stock block then a sleeved, pistons/rods combo and a hack or fmu |
#6 |
so can I use a gsr water pump, oil pump, and timing belt in my b18b with a LS head?
#7 |
my name is Dale
actually i take me last statement back. what rpm are you going to go to? if over 7500 go with a vtec water pump if not stock is fine. vtec water pumps have more teeth onthem so it pushes less water but is better at higher rpms.
#8 | |
thistownsucks...
#9 |
I am not going to be taking this motor over 6.5K at any point.
#10 |
Ride: 1997 Integra
i have both a gsr oil pump and a gsr timing belt kit w/ water pump if you want. the water pump and kit are brand new and the oil pump was inspected and i believe resealed so it is like new. tell me what you think.
![]() Like water on a duck's back, just let it roll off... |
#11 | |
thistownsucks...
matt __________________
#12 |
all yours hybrid
#13 | |
Ride: 1997 Integra
matt [/b][/quote] $200 not shipped for both, but where are you located because im willing to meet you. but shipping shouldnt be that much anyway. __________________
