Any one have a DIY on a Replacing DOHC V-TEC Headgasket
Old 08-13-2006, 12:05 AM   #1
93delsolsi's Avatar
Ride:  Del Sol
Rep Power: 11 93delsolsi is on a distinguished road
Send a message via AIM to 93delsolsi myspace
Default Any one have a DIY on a Replacing DOHC V-TEC Headgasket
93delsolsi is offline   Reply With Quote
Old 08-13-2006, 05:39 PM   #2
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
lollers, yeah, it's called a helms, and they'll run you about $60 online. If you want a quick how to....
0. Disconnect Battery, Drain Oil and Coolant.
1. Remove Exhuast manifold.
2. Remove/Unbolt engine accessories up front. (AC, PS, anything attached to the front of the head.
3. Remove intake tubing.
4. Diconnect throttle cable and vacuum hoses form intake manifold. LABEL EVERYTHING.
5. Disconnect all sensor wires from the head. Vtec solenoid, ECT, IAT, IACV, Injectors Harness
6. Disconnect fuel feed and return from filter and fpr respectively, and disconnect fuel rail. Move the injector harness out of harms way.
7. Disconnect and remove distributor and ignition wires.
8. Remove Intake manifold.
9. Set No. 1 cylinder to TDC at some point before now.
10. Remove valve cover.
11. Remove cam oil galley thingies that sit on top of the cam caps.
12. Remove cam caps, evenly releasing valvespring pressure on all the caps.
13. Remove cams.
14. Loosen head studs in proper order.
15. Head should be able to come off at this point.
I might have missed a step, but this is the general way to get it off, hope it helps.
Mike
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 08:50 PM
DOHc Vs SOHC mark80 General Tech and Maintenance 10 05-12-2006 01:41 PM
B18c Inline Pro 3mm headgasket...$125 colorpros Parts: For Sale/Trade/Wanted 3 11-19-2003 09:45 AM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 07:36 PM
92 DOHC ZC SWAP vtechkidd HYBRID -> ED-EF / DA 4 10-27-2003 02:40 PM
