This is a discussion on Axle Snapping? in the General Tech and Maintenance forum
This civic I am looking into getting is putting down ~400HP to the front wheels. The guy selling it says it has Acura GSR axles (if I remember correctly). Im worried they might snap, has anyone else got experience with this?
If your axle DOES ...
| | #1 |
| This civic I am looking into getting is putting down ~400HP to the front wheels. The guy selling it says it has Acura GSR axles (if I remember correctly). Im worried they might snap, has anyone else got experience with this? If your axle DOES snap what exactly happens thereafter....I have seen videos of cars axles snapping and their tires even falling off after this. I don't want that to happen on the highway....someone could get killed. |
| | #2 |
| honda axles are pretty stong. You shouldnt have a problem unless you launch at a high rpm with slicks. The car wont move after it breaks. THe only time you should worry about an axle breaking is when you have a welded diff otherwise dont worry about it. You should be ok. GL |
| | #3 |
| 400WHP is enough to break a stock axle even with a stock transmission.. especially if he puts on a set of drag slicks. However, the tire will definitely not fall off if you break an axle, most likely it will just snap and you wont be able to move the car if it breaks while launching. However, if you have an LSD or a spool on the trans and it breaks while you're driving it hard (such as down a 1/4 mile at WOT) you could put it into the wall especially with a spool/welded diff. All the power will transfer to the one axle that isn't broken and push you right off the track.
__________________ Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information.. |
| | #4 |
| as he said^^ it could snap..the wheel will not fall off..and the only problems you might encounter are the axle hitting/breaking something or the car losing control^^as he said again....if your that worried about axles snapping there is a site that sells axles in stages(ex. 1,2,3,4) |
| | #5 |
| Hmm. I don't know if this will help or not but right now it has a manual boost controller and is set for daily driving at ~12psi, and for racing he turns it to ~16-18psi. I wanted to switch to the Apexi boost controller that allows you to adjust the boost through each gear and reduce tire spin. Ex... 1st gear turbo maxes out at ~8psi, 2nd gear ~10psi, 3rd ~ 12psi, 4th~ 14psi, 5th~ 16psi or something like this (to keep from tire spinning in almost every gear). What kind of axles do most people putting down this type of power use? Could someone link me to some decent ones? Thanks guys Last edited by CARP 104; 11-17-2007 at 08:51 AM. |
| | #6 |
| YOu should be allright with stock axle as long as you dont run 24" or bigger slicks. If you do, just feather the clutch on the launch and you should be ok. Id say your tranny will fuck up before the axle does. :-) |
| | #7 |
| SAVE on Fidanza CV Axles - RacingWorks.com - Fidanza Race Axles those hold up to 300hp ZEX™ Super Duty Race Axles these are for certain applications Gator Racing Axles-pictures thses are also application specific... and you don not feather the clutch when launching |
| | #8 |
| put 800hp axels in your car thats wat i did..guranteed not to snap they are also like $800 but better to be safe then sorry |
| | #9 | |
| Quote:
bahahahahhahaha. you suck. I know what im talking about. Ive been drag racing for years... :-) Im making 450+ whp on low boost and still rocking stock axles. SON. | |
| | #10 |
| lol first off i aint your son and second off why must you make a big deal out of something like being on the safe side with axels just cause i have 800+ hp axels just mean mine arent goin to snap so stfu and go bk to your mom and have her call you son. |
| | #11 |
| My driver side axel is fucked thanks to motherducking nitrous |
| | #12 |
| ok asshole...drag racing for years....you obviously dont know shit about anything and you obviously only drive the car...feather the clutch on a launch?!?!then how the fuck are you going to get a good launch if your feathering you dick munch....you will need stronger axles for the application and what car do you run low boost with 450+hp?!?!? i sure as hell no its not a honda with stock axles...SON!!! |
| | #13 |
| oh they will snap, but the car just stops moving until you put a new one in |
| | #14 | |
| Quote:
Low boost 18psi. You drive a POS honda civic with a d series. SHUT THE FUCK UP. My helmet cost more than your whole setup. SON You guys suck. Fuckin' nOObs | |
| | #15 | |
| Quote:
i drive a crx with an UnKnOwN MOTOR... and im pretty sure your helmet didnt cost more than my setup...soo basically u can bang your ass...you think you can talk shit and act big "oh i drive a civic with low boost.its only at 18psi..i dont work on the car or know shit about it..and im on stock axles and when launching i feather the gas" suck a dick..and dont provide false info..FAGGOT | |
| | #16 | ||
| ohhh and look....Here you go nOObs. If you have the money, go get yourself gator or dss axles. Im just saying you dont really need it unless youre going to be at the track 24-7 ![]() LDL speedshop In CA. Quote:
Flamenco from texas Quote:
| | #17 | |
| Quote:
Look at my build thread and then talk shit. I build FAST cars for a living... hahaha I make more money in a week than you and your brother will ever make in your entire life. lol God this is too funny. Try again | |
| | #18 |
| Estorvito will put a knife in you, son. |
| | #19 |
| yeah klyph. Fucking nOObs dont know shit... |
| | #20 |
| I like how he said you don't work on your car What a tool, kid can't even wear a hat correctly. Hey INJEN, keep your thuggin on the skreets, we don't need your bullshit in the tech forums. |
| | #21 | |
| yeah thanks bro.. I just did a search and found this... THe one drives a 1.5 crx.... bahahahhaahahahah UNKNOWN engine? lmao.... My daughters power wheel will take you heads up. jajaja so let me get this straight Troy. You were talking shit and all you drive is a pos crx? what a tool. Dont get me wrong its a nice rex, but the engine is crap...lol his crx with 1.5 single cam. <---yep 1.5 single.. God help me. and him. 'picard goes here' ![]() Quote:
| | #22 |
| Give up.? |
| | #23 |
| lol yea man u got me...and my fault..i havent been having the best day..soo i apologize for talking shit...i do see your point about the whole axle deal...and yes thats my rex..and no its not a 1.5 single...it just says that..but anywayz i apologize again EDIT..and i must say those are some old ass pix lol....time for an update |
| | #24 |
| no worries |
| | #25 |
| PATHETIC! |
Similar Threads | ||||
| DIY: How to change an axle | Calesta | General Tech Articles | 1 | 05-20-2005 08:30 AM |
| Axle Question | slammedcivic | HYBRID -> EG-EK / DC | 6 | 07-02-2004 10:34 PM |
| Axle Clicking Problems, For The 3rd Time.... | sol2nr | HYBRID -> EG-EK / DC | 6 | 05-23-2003 11:38 AM |
| Axle Woes | dkasakitis | HYBRID -> EG-EK / DC | 8 | 02-13-2003 07:18 AM |
| Which Axle | GSRCRXsi | General Tech and Maintenance | 2 | 01-31-2003 02:56 PM |
