| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | Ok, i'm putting an LS motor in my 92 CX hatch, and I've already got a B16 timing belt (that was originally for my 99si), GSR Water pump and STR cam gears. A shop in my area told me that as long as i change my water pump that belt would fit. Well i put the STR cam gears on, put the water pump on, and the belt does not fit. To me it does not seem long enough. When they told me the B16 belt would fit, i thought i would have to use a gsr belt because i thought that B18 blocks were physically taller. Is this the case or do i just need to try harder? Thanks in advance. |
| | #3 |
| Junior Member | Once you switch to a GSR water pump, you can't use the LS belt because there are 19 teeth on a LS pump, and 22 on the GSR and any other vtec B-series water pump. If i were to put an LS belt on, it would be destroyed shortly. I guess i will just have to buy a GSR belt since that seems to be the solution. |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 28 | 02-08-2010 09:43 AM |
| Timing Belt Repleacement | closedhood97 | General Tech and Maintenance | 9 | 02-09-2007 11:43 PM |
| ZC timing belt??? | twotwo | General Tech and Maintenance | 8 | 04-25-2004 10:14 PM |
| lsvtec ls timing belt | lsvtecguy | Engine Building | 2 | 02-08-2004 11:08 AM |
| how to time | minivan | HYBRID -> ED-EF / DA | 2 | 02-03-2004 01:33 PM |
