hey, i was wondering if anyone knew how to fix my vtec problem
b16a swap wit p30 ecu. vtec doesnt seem to work. maybe only in first gear. engine check light appears after 6000 rpm. could it be my o2 sensor? vtec solonoid or it's not picking up the oil pressure for vtec to hit? thanks |
A good thing to check are the three main things VTEC needs to work:
First is Oil Pressure Second is that the car must read that you are in gear. Third, It must know that you are going somewhere over 20 or 25 MPH (I don't know for sure, but basically it needs to have a working spedo) There could be more, I can't remember, but these three usually will lead you to the problem. Ian __________________
2003 Infiniti G35 1992 Civic Si Hatch JDM B18C, with a B16 head, and B16 Tranny on P30 ECU Civic Type R Cams on stock valve train, uprgade to Skunk2 IM soon... AEM SRI, Greddy 4-2-1 header, 5-Zigen Fireball Catback H&R Race Drop, KYB AGX 4 way adjustable Shocks 00 GSR Wheels in Goodyear GS-D F1s Skunk2 Upper Control Arms EBP paint 1996 Civic CX Hatch - R.I.P Dec. 26, 2002 |
i was having the same problem, it you look ar your ecu it will throw lights (codes) mine was throwing a oil pressure switch code which is the vtec solenoid i and i would reset the batt. and every time i would enter the vtec rpm range the check engine light would come hope that helps
If it aint a HONDA I ain't impressed!!!!!!!!!!!!!!!!!!!!!!!! |
#4 | |
| B16A Variants | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:31 AM |
| 2nd gen Integra Swap Info | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:16 AM |
| B16A SiR 1 into a 5th gen chassis | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:12 AM |
| Part Numbers for 89Si/B16 OBD0 Swap | steelbuster | Swap Articles | 0 | 11-16-2003 07:36 PM |
