B16A2 numbers?
Old 06-29-2004, 09:17 PM   #1
Rep Power: 13 bdogggut34 is off the scale
Anybody have some HP and TORQUE numbers on a boosted B16a2 on about 5-8 psi? I'm looking to run mid 13s to high 12s and was wondering if this motor is capable of this on lower boost without completely building internals? Going into a 92 Si hatch.
bdogggut34 is offline   Reply With Quote
Old 06-29-2004, 09:34 PM   #2
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
boosted, depends on the altitude and other factors...um I'll guess about 210 hp/140 ft lbs... I dunno. I just know you won't get 12s with that in a heavy 92 Si hatch. Get a EG VX hatch, weighs something like just over 2000 lbs, do a weight reduction and you might see 13s.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 06-29-2004, 10:15 PM   #3
Rep Power: 16 beerbongskickass is off the scale
Send a message via AIM to beerbongskickass
A boosted b16a2 should have no problem getting into the 12's. With good fuel management and tuning a b-series motor should be able to handle 300whp. My civic coupe on slicks is almost in the 12's and i have a stock d16z6 boosted.
Turbocharged 95 Civic w/stock D16Z6 - 230whp/208wtq thanks to www.HomeMadeTurbo.com and uberdata
beerbongskickass is offline   Reply With Quote
Old 06-29-2004, 10:22 PM   #4
2265787829
2000Si's Avatar
5-8 psi is not going to net 300 whp.
Old 06-29-2004, 10:49 PM   #5
Rep Power: 13 Import R is off the scale
Send a message via MSN to Import R
depends on what turbo it's from.
Import R is offline   Reply With Quote
Old 06-29-2004, 11:24 PM   #6
I know, but from reading his question it sounds like he wasn't sure if his motor could handle much more than 5-8 psi with stock internals. I was simply stating that it could handle quite a bit of power and be reliable with proper tuning and good fuel management. I think it's a waste to run such low psi on a b16a or b18c considering how far you can push these motors with stock internals.
Old 06-30-2004, 06:56 PM   #7
Alright, so how much can it "safely" handle on internals then? I honestly was just guessing that low boost like 5-8 would be max on stock internals. I definitely want 13s, but be safe about it also.
Old 07-05-2004, 05:16 PM   #8
Anybody?? How much more is it gonna take to get me into the 13s with a B16A2?
Old 07-05-2004, 05:49 PM   #9
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
What car? can you drive? What tires? What suspension? On a side note, B16A2's have seen 13's in hatchs with I/H/E, and some great driving.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-05-2004, 10:44 PM   #10
tru ^^
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
