I am really having a tough time finding the differences between the B16 head and the B18C head. I've searched for 3 days now and I can't find what the differences are. Maybe I'm a shitty searcher! I am of the mind that if hondaswap doesn't have it, then I most likely don't need it! I haven't been as throe on other sites.
I know the cams are different but I am more interested in the physical head differences, if any (besides the shitty port job the type R has), and if the valves/valve guides are different between the heads. I know the Type R has different intake valves but the exhaust valves are the same as the GSR. Second is the Hondata Intake gasket or similar worth the 65 bucks? Also in the race version where you have to re route coolant lines is the corner of the head that is now blocked off noticeably effected as heat dissipation goes? Third are the ARP head stud bolts worth while? I know I have read that Hondas are just fine with the stock head bolts when going boost. I almost always anti-seize bolts that I remove before I reinstalled them but I am thinking that I shouldn't when I reinstall the head studs. Any positive input is appreciated. ![]() |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
the heads are almost the same.....the gsr cams are better for FI and the IM sucks.....but ive seen dyno graphs on this site where both heads flow almost identical....one is like 1-2 hp better low and the other 1-2hp better at higher rpms....pick one....i like the b16 its the same cast as b18c5.....but its up to you...
get the regular hondata gasket and get the real thing i dont see the need for one but its just me....some might.... .yes arp makes a great product....i used head studs and rod bolts on my lsv......dont use antiseize....use the lube they give you..... __________________
before i answer, when you say b18c do you mean the gsr or the type r? this will matter alot on the answer.
#5 |
gsr head is different than the type r and b16 head.
b16/type r = same cast different internals gsr = different cast gsr intake manifold isnt crap, its crap if you dont have the right ecu. gsr manifold can easily have the secondaries removed and gutted since it comes apart in the middle. gsr head has square combustion chambers bumping compression slightly over the other 2. i personaly went with the gsr head because i believe it will yield more power down the road with the same mods as on a b16 head. __________________
LS vtec build http://hondaswap.com/auto-multi-medi...t=lsvtec+build New GSR build 2009 http://hondaswap.com/auto-multi-medi...5/#post1400802 |
#6 | |
ARP head studs? good quality. and type are doesnt have shitty port job, at least not as shitty as the gsr if you look at it that way. __________________
95 Honda Civic D15b7 Piece together short ram Bomz Cat - 2 1/4 Pipe - Bomz Muffler Aem Fuel Rail - Stock 240cc GSR Injectors And low 10's on the 8th |
#7 |
B16/type r: Open Pocket Combustion chamber
GSR: Quench area Pocket Combustion chamber GSR will yeild more comperssion but the Pr3 heads will yield more volume. b16 and ITR have diferrent bolt pattern than the GSR but the same on exhaust. __________________
1991 Honda CRX Si, JDM B18C GSR Swap, AEBS Manifold, CTR Pistons, DPR ITR Stage 5 Head, Skunk2 stage 2 Cams, Skunk2 cam gears, AEM V2, ANR Header, Greddy E-Manage, ACT 6 puck clutch, AEM fuel rail, Eagle Rods, Type R tranny, Enjo axles, Runs 12.8 ALL MOTOR! |
#8 | |
B happy
Ride: dohc 95 egg
ARP head studs? good quality. and type are doesnt have shitty port job, at least not as shitty as the gsr if you look at it that way. [/b][/quote] Actually, no, it doesn't flow a lot better than the GSR head, both have their advantages throughout the RPM range. and the difference isn't that big anyway. Not to mention the GSR head will yield high compression because of the shape of it's combustion chambers. __________________
#9 |
to john. the b16/gsr heads are almost identcal in terms of flow. they do differ, but its really negligable. the type r only flows more because it has a stock mild port job. its not even that great of a port job. your better off taking a stock gsr or b16 head and getting it professionally ported. it will make way more then the type r. basicaly everything between the b16 head and type r head are th same besides whats actually inside. they both come from the same cast. and both share all the same intake bolt patterns. gsr and b16 are widely different. different casting. gsr has squared off combustion chambers which alone bump compression about .2 over the b16. it also has a different intake bolt pattern. intake manifolds will not swap between the two without a good bit of modification. the only reason people choose the b16 head over the gsr when building a motor or whatnot is the price. and b16 heads are more common. personally i agree with vtecsir1 about the gsr head making more power then the b16 head mod for mod, simply because of the increased compression |
#10 |
Cool. I'm learning a lot about the differences on the head but can anyone say if the valve stems or valve guides are the same size throughout the family. I am almost positive that they are except the Type R intake valves are a little lighter.
Also any more input on the hondata gasket or the arp studs. It sounds like not to many people feel as though they are worth while. Granted both companies make great products but I'm looking and the useful/worth my 200 bucks factor? |
#11 |
B happy
Ride: dohc 95 egg
Well, the Hondata gasket works. If I was boosting, I'd do everything I could to keep intake temps down. As far as the head bolts. I wouldn't reuse them, if you don't get the ARPs, use new Honda ones.
#12 |
Ride: '92 Civic CX
also, the upper radiator outlet are in different locations. On the gsr head, it is more toward the front (exhaust side) of the head, and on the b16/type r head, it is towards the back, kinda underneath the distributor.
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#13 | |
arp head studs are good and worth the money. hondata intake gasket works but you can find a copy cheaper that does the same thing, its just plastic its not like their gasket is superior. i wouldnt buy an ebay gasket but there are other companies at half the cost of hondata. a friend in town was making them but at twice the thickness for like 30 bucks. i dont know if he is still making them or not. http://www.rpiracing.com __________________
#14 |
Stylus DJ Extraordinaire
I love this site and how knowledgable the people here are.
![]() __________________
DC Squad Member # 0631 I used to have my rides in this section but there are too many thieves out there trying to jack. I HATE THIEVES |
