B18C idles like crap and dies at stop lights
Old 10-22-2009, 12:34 AM   #1
raysee's Avatar
Rep Power: 1 raysee is on a distinguished road
myspace
Default B18C idles like crap and dies at stop lights
I have spent about 4 hours looking at previous posts for a similar problem. I can't find an answer so I thought maybe I should just ask. I have a 2000 Civic SI with a B18C (ITR) motor, tranny, and ECU swap. The car has had MANY small issues over the years and here is another one. The car idles at about 250-500RPM usually but will sometimes idle normally (750-1000 RPM). The car is as great as it ever was as long as the gas pedal is depressed. Doesn't matter if I am going 25 MPH in a construction zone or if I am on a country road with the pedal to the floor listening to the beautiful sound of the N/A motor roaring the Apexi NOIR cat back exhaust. Pull up to a stop light, idle returns to retarded mode and the car dies. Does this sound like a fuel pump issue? I say no because if it was, wouldn't the car act up all of the time? I have new MSD 8.5 wires, new plugs, clean air filter, fuel filter is less than 1 year old, fuel injectors ohm tested good, and I cant find any cracked or broken vaccum hoses. Any help will be greatly appreciated.
raysee is offline   Reply With Quote
Old 10-22-2009, 01:50 AM   #2
raysee's Avatar
myspace
.............I also want to let u guys know that I have unplugged the IACV and the car dies. From what I have read, on my car...this is the desired result. No I haven't cleaned the IACV, but it did respond appropriately when I disconnected it. Should I clean it or is this test enough to ensure that it is fine?
Old 10-22-2009, 05:00 AM   #3
Token GM Guy
double0Si's Avatar
Ride:  91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
Rep Power: 119 double0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
double0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
myspace
I'd clean it to be on the safe side.
Si vis pacem, para bellum
There are no stupid questions, but there are a lot of inquisitive idiots.
TWIN Turbo V8 CRX
Originally Posted by 93civicracer View Post
I'm a real enthusiast for Japanese cars, I like the small things here n there that are different on jdm vehicles like lips, foglights, and the tiny differences especially the emblems for some reason.
double0Si is offline   Reply With Quote
Old 10-22-2009, 11:58 AM   #4
Greenhorn
Ride:  92 honda prelude
Rep Power: 0 hondajunkie92 is on a distinguished road
hey u might wanna try your mad censor, if its out it wi cause your car to idle crappy and die let me know how it goes
hondajunkie92 is offline   Reply With Quote
Old 10-22-2009, 11:59 AM   #5
Greenhorn
sorry i ment to say map censor
Old 10-22-2009, 12:03 PM   #6
Rep Power: 6 93y7 is on a distinguished road
any vacuum leaks? i would check that too
93y7 is offline   Reply With Quote
Old 10-22-2009, 07:56 PM   #7
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 51 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
did you ever mess with the throttle stop screw or the tps sensor (DONT!). did you try the idle adjustment screw at all?
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-22-2009, 08:38 PM   #8
raysee's Avatar
myspace
I knew what u meant,
Old 10-22-2009, 08:39 PM   #9
raysee's Avatar
myspace
i didn't want to, but i guess i will. Just remove it and clean it with what, TBI cleaner?
Old 10-22-2009, 08:40 PM   #10
raysee's Avatar
myspace
I have looked, but not found any
Old 10-22-2009, 08:43 PM   #11
raysee's Avatar
myspace
I haven't messed with any of these. Remember, sometimes it idles okay, should I still try the idle adjustment screw, and where is it if so?
Thanks guys, looks like I got a lot more shit to look at at.
Old 10-22-2009, 10:08 PM   #12
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
try to cleanthe iacv with some throttle body cleaner and also look all over for any loose wires
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 10-23-2009, 02:28 AM   #13
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
I don't think it would be a vacuum leak, it would idle high and surge.
Timing set? Clogged cat? Any CEL's?
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is offline   Reply With Quote
Old 10-23-2009, 10:53 AM   #14
raysee's Avatar
myspace
I don't know if the timing is correct, i don't think the cat is clogged because it is a "high performance" cat (straight through), and there are no CEL's which doesn't tell me shit anyway because even when my primary O2 sensor went bad, there was no CEL. I chased that problem for about a year and a half before someone said replace it anyway and see what happens. I think my "buddies" took some short cuts when they helped me do the swap. Good info, I will clean the IACV hopefully this weekend and see what happens, but first, I gotta work on my Taurus (DD)
This is the first time someone said they did NOT think the problem is vaccum related. Just an FYI
Thanks again guys
Old 10-23-2009, 01:00 PM   #15
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
Clean the IACV and FITV(if you have one). The issue is not vacuum since you're idling low, not high. And yes, try replacing the primary O2 and also check the TPS voltage(range should be something like .5-4.5v between closed and WOT).
My brother had very similar issues but was O2 related. No CELs either.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 10-24-2009, 03:52 PM   #16
raysee's Avatar
myspace
Yesterday bwas the first time I have drove the civic in awhile. It started cutting out and acting as if it were starving for fuel again (this is how it acted when the O2 sensor went out). Then today, I removed the IACV and gave it a good cleaning. While I was waiting on it to air dry, I cleaned the throttle body. I have never done so before, so what does normal look like? I sprayed the throttle body cleaner into the throttle body without opening the throttle plate, but when I wiped out from behind the throttle plate, there was a whole bunch of dirty shit back there, I mean a LOT. anywho, I put everything back together (installed IACV), started the car and it idles at about 500 rpm all the time now. I reved the RPM to 3K held for a couple of minutes and let the RPM come down to normal. Instead of idling, the car dies. I started it back up and it idles at 500 again. Rev up to 1,500 RPM this time, release the gas pedal and the car dies again. I did this probably 15 times and each time i left off of the gas, the car now dies. Anyone else think I screwed something up? I cant test TPS until I get a multimeter or have a friend of mine come over, but I will ASAP.
Old 10-24-2009, 03:54 PM   #17
raysee's Avatar
myspace
No FITV either, I have a 5 spd
Old 10-24-2009, 08:47 PM   #18
SOHC on this!!
Possibly in the dizzy.
Old 10-30-2009, 07:07 PM   #19
raysee's Avatar
myspace
UPDATE:
I tested the MAP and TPS sensors. On the MAP sensor, the voltage on the connector is good and so is the votage at the sensor. On the TPS sensor, the voltage to the connector is 5.0 volts which is where it should be. When I tested the sensor, the volts started at 0.2 volts with the throttle closed. as I opened the throttle, the volts raised to 4.2 volts steadily. Now the Haynes manual says that the volts should start at 0.5 and steadily increase to 4.5 volts as the throttle goes from closed to WOT. is this difference of 0.3 volts an issue or am I okay? Also, I had to use a jumper wire from the volt meter lead to the straight pin that I back probed the connecter with. Could the jumper wire create the 0.3 volt deficit?
Old 10-30-2009, 08:00 PM   #20
99sidude's Avatar
you're fine with it being .3 off at wot
93' dx hatch
s300 440cc RC's
Old 10-30-2009, 10:30 PM   #21
K2e2vin's Avatar
The problem is not so much WOT, but rather the closed position. If you can't rotate it to get the voltage range needed, replace it, as this will cause a problem(and probably is the source of your problem).
Get the TPS fixed.
RIP
Old 10-31-2009, 07:08 PM   #22
raysee's Avatar
myspace
HAHAHA, here is my problem, 1 guy says leave it and 1 guy says fix it. I admit I dont know a lot about this issue so I am asking but it is hard to know what to do when one person says fix it and the other says it is fine. If I do replace it, is there a specific one I should buy? I know a lot of companies sell TPS sensors (except Honda of course), so which (if any) is of the better quality?
Old 11-01-2009, 05:49 AM   #23
K2e2vin's Avatar
being off by .3 is a LOT especially considering closed position is at .45-.5.
It looks like the TPS is fine; it just needs to be rotated. Just loosen it; and rotate it until you get about .5 for closed position. If your TPS has the "rivets", just get a dremel or fine hacksaw and put slots in it to take it out/loosen it with a flathead screwdriver(for my brother's car I just replaced it with bolts).
RIP
Old 11-02-2009, 09:33 PM   #24
raysee's Avatar
myspace
Thanks for the advice, I will try it tomorrow (Tuesday) hopefully.
Old 11-09-2009, 07:35 PM   #25
raysee's Avatar
myspace
UPDATE:
I adjusted the TPS and now have the correct voltage readinds (0.5 closed throttle and 4.5 WOT). The car still has its problem but now is cutting out really bad when I am driving the car. I am gonna test the primary O2 sensor next weekend unless somebody has any better suggestions.
holy crap, we're in deep crap!!!! jeffie7 Members' Lounge 12 06-22-2005 01:16 AM
car idles like crap and gas is in the exhaust LsB16CrxHF General Tech and Maintenance 3 05-07-2005 11:47 AM
Engine idles good, btu like crap at 2,500 69crx69 HYBRID -> ED-EF / DA 5 09-28-2004 11:01 PM
Civic Dies At A Stop randerson165 General Tech and Maintenance 6 01-17-2003 04:01 PM
