B20b longblock dilema
Old 05-17-2009, 11:14 AM   #1
learning in progress
formby's Avatar
formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
Exclamation B20b longblock dilema
After dropping a valve about 3 weeks ago. i decided to buy a used b20b long block from a place in NJ. for the start of my b20 small turbo project.
I received in in 3 days and it looks really clean and for some reason it looks to have been taken apart or really well maintained.but that's just a double edge sword
the good:
cam caps have honda bond
rear main seal plate also had HB
the exhaust and intake ports are clean as fuck only #3 intake is dirty.
the block looks really clean
timing belt has a little dirt on it but it looks good
no rust
all the bolts were there and not stripped
all sensors are intact
i can see clean pistons through the spark plug hole. it looks like a circle inside a circle, ive never seen a piston like that. also the head gasket looks to have been sprayed with copper
which brings me to my concerns / the bad....
wouldn't the engine have carbon build up specially on the pistons?
the cam marks do not line up and the rear black cover is hitting the cam sprockets. one of the spark plugs was also with out a gap, looked like some one pressed it or the piston touched it.
i am going to change the oil/water pumps and TB from my old engine.
but i don't know if i should set the timing the way it was or if i should set it at spec?
if the head was milled because of an over heating then the timing marks would be set up right.
what would you guys do?
http://pandora.com/
Old 09-23-2009, 01:45 PM   #2
78civic will become famous soon enough
Did you find anything 'wrong' with your motor?
E
78civic is offline   Reply With Quote
quite the dilema alaskancodkiller Members' Lounge 17 08-01-2005 09:53 AM
my dilema. CRX-YEM Members' Lounge 6 05-21-2004 04:52 PM
CAM dilema e money 9 HYBRID -> EG-EK / DC 3 02-14-2004 07:48 PM
my teg dilema UDT General Tech and Maintenance 35 11-15-2003 04:46 PM
Dilema koi_killa HYBRID -> EG-EK / DC 9 02-12-2003 01:47 PM
