B20VTEC compression ?'s
Old 11-11-2003, 12:51 PM   #1
Rep Power: 18 EGLSHB is off the scale
Send a message via AIM to EGLSHB
OK....
What CR pistons will i need to go with in order to achieve
a static compression ratio of 10:1-10.5:1?
i have heard that the 9.5:1 pistons in the B20 are said to make for almost that ratio, when using a B16 head for the conversion
do you guys understand what i am asking?
i want to maintain a similar CR to that of my stock B16, so that if i want to add a SC, or low-boost turbo setup down the road, it will still be ok.
but, i also want the B20VTEC to make good power without the FI....
FYI: i will be running Golden Eagle sleeves, forged rods/pistons, etc...
and plan on a small nitrous setup for starters
EGLSHB is offline   Reply With Quote
Old 11-11-2003, 03:45 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Make up your mind about boost or not before you buy your pistons. A good static compression ratio for all motor performance does not equal a good static compression ratio for boosted performance. Well, maybe if you want to run a small low pressure turbo on top of high compression pistons...
Endyn makes great pistons that are spec'd to the B20 bore and a B16 head. Try them out to find the compression you want.
Old 11-11-2003, 05:29 PM   #3
i want to have either a little boost, or nitrous, and i am not looking for world-slaying all-motor power, i just don't want to spend big money on a bottom end, and only make 5 or ten more Hp because the compression is too low...
oi want it to have comparable compression to what i have now, so i know that i can run a SC or turbo intended for stock CR later if i want to'
Old 11-11-2003, 10:30 PM   #4
pistons I would go with weisco/endyn RW's, rods I like crower, as far as your CR ratio check out Cspeeds site and their is a conversion chart for B series motors, heads, etc.
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
compression, octane, and boost rjbaker Engine Building 6 01-24-2004 04:03 PM
Static vs. Effective Compression pissedoffsol Turbo Information 0 01-12-2004 01:43 AM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
Girl needs help Baccidamorning HYBRID -> EG-EK / DC 52 07-20-2003 02:19 AM
High Compression & Nitrous michaelgomez Forced Induction 1 06-06-2003 02:57 PM
