backfiring too much and not going anywhere
Old 05-18-2007, 03:39 PM   #1
Rep Power: 6 xxiong88 is on a distinguished road
Default backfiring too much and not going anywhere
My car is B18A1 in a EF civic. My car has codes 5, 10, 14, and 43. Not sure what to do. My car was running fine but I went to fill up the gas and parked it for a while. I drove it for a few minutes then it just lost power and started to backfire non stop. When you try to floor it, backfires even more. What is wrong with my car?
xxiong88 is offline   Reply With Quote
Old 05-18-2007, 03:46 PM   #2
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
fix the codes!
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 05-18-2007, 03:53 PM   #3
5 MAP - manifold absolute pressure sensor
10 IAT - intake air temperature sensor
14 IAC (EACV) - idle air control valve
43 Fuel supply system
What do I do to fix these things?
Old 05-18-2007, 06:22 PM   #4
it might be the fuel problem. not sure what to do right now.
Old 05-18-2007, 11:07 PM   #5
i would check the wiring for those sensors... and your fuel pump?
Old 05-19-2007, 11:26 AM   #6
we found the source of this crap. It was the rotor inside the distributor. It was off, the screw came off. We got a new cap and rotor so its all good now. Too bad it couldnt shoot a code for distributor. My car almost blew up. It is fixed now and driving great.
Old 05-19-2007, 01:35 PM   #7
V8 EATER!!
Ride:  1993 hatch
Rep Power: 8 1994turbodelsol is on a distinguished road
good to hear
1994turbodelsol is offline   Reply With Quote
Old 05-29-2007, 02:48 AM   #8
Rep Power: 0 zerokool007 is on a distinguished road
i got a 1991 crx si and i want 2 do a b18 with a b16 head i belave its called a ls vetc any way i need 2 know what i have 2 do 2 do this please let me know its has a 1.6 in it but i have a b16 and a b18 motor so please help thank you chris
1991 crx si
1990 crx si selling parts
1987 toyota supra turbo 4 sale 2500 obo
1998 mit evo
zerokool007 is offline   Reply With Quote
Old 05-29-2007, 04:36 PM   #9
1991 crx si
1998 mit evo
The LS/VTEC Swap
this guide should help with the swap. You should be able to use the crx si wire harness or probably the b18 wiring. you also need b18 axles for the swap, swap shift links and swap motor mounts. I have never done lsvtec before. I only have the B18A1 in there that doesnt have vtec. Might have to do a little wiring to get the vtec to work. cant help you much.
