Bad Fuel Pump?
Old 10-11-2005, 10:27 PM   #1
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
So, i think my fuel pump is fried, changed main relay, all fuses are good, dont hear the "whine" when the key is on the on position. I think it may have gotten fried when i was extending the wires for my map sensor to use a map sensor mounted on the throttle body on my skunk2, i was re-wiring it when i lost a wire and it touched the positive terminal of the battery, causing a spark.
Is there any other ideas of things to check first?
DB8 450whp project......
VTECPOWER is offline   Reply With Quote
Old 10-11-2005, 11:08 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Take out your pump, dump it in a bucket of oil, wire it up and turn it on..
Old 10-11-2005, 11:17 PM   #3
Is there any way to test it electrically?
Old 10-11-2005, 11:23 PM   #4
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 179 reikoshea has a reputation beyond repute
myspace
12v dc and ground?
Anime Informant
reikoshea is online now   Reply With Quote
Old 10-12-2005, 09:57 AM   #5
My dad checked some things online thismorning and we will check out a few things electrically before going and replacing this bastard.
Old 10-12-2005, 10:20 AM   #6
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
look for the possitive wire on the pump harness and just tap it and run 12v to it.... it should turn on with out a ground...its grounded on the pump housing in the tank...
http://pandora.com/
Old 10-12-2005, 10:30 AM   #7
With mine, someone did something, and it's grounded to the chassis, theres a wire nut near the housing in the interior, and a wire runs to a bolt for a ground.
Old 10-12-2005, 11:00 AM   #8
formby's Avatar
okay just tap into the positive wire on the harness....and it should turn on if not....do the oil thing...never heard of it but try it
http://pandora.com/
Old 10-12-2005, 11:19 AM   #9
So just run the positive wire on the fuel pump to a 12v source. Thanks.
Old 10-12-2005, 11:29 AM   #10
formby's Avatar
yup.....
http://pandora.com/
Old 10-15-2005, 07:29 PM   #11
Rep Power: 9 spoonfedcrx is off the scale
this might be a stupid question but if u touched the positive terminal and seen a spark and now ur pump doesnt run did u check the main battery fuse to see if its blown. if u already have disregard and listen to those guys
spoonfedcrx is offline   Reply With Quote
Old 10-15-2005, 09:22 PM   #12
Ive checked all the fuses, my ecu is fried, ordered a new one, because the led light stays on, and you can see where the solders are broken.
Old 10-17-2005, 05:07 AM   #13
HS Troll...And Mod
reikoshea's Avatar
myspace
ouch...sounds painful.
Anime Informant
Old 10-17-2005, 06:04 AM   #14
Yup, $140 painful, pr3 should b in today.
Old 10-17-2005, 03:14 PM   #15
Got the pr3 today, fixed an exhaust leak, [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] all good now!
