Battery or Alternator
Old 10-23-2002, 12:17 AM   #1
Rep Power: 15 import_racer is off the scale
I forgot, how can you tell if the battery needs to be replaced or if its the alternator that needs to be replaced? Thanks.
import_racer is offline   Reply With Quote
Old 10-23-2002, 12:23 AM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
if the car starts then dies after youve been driving it its the alternator ... if it wont start but once you jump it it runs fine its the battery
МОΛΏΝ ΛΑΒΈ
Old 10-23-2002, 12:24 AM   #3
CRX-YEM's Avatar
Ride:  91 CRX
Rep Power: 86 CRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud of
Send a message via ICQ to CRX-YEM Send a message via AIM to CRX-YEM Send a message via Yahoo to CRX-YEM myspace  FaceBook
if it's the battery the car will prolly start hard after a long night or it might even bee dead in the morning. but onve you get it started the car will run off the alternator.
if it's the alternator if you're drivin short ditances you will prolly be able to make it places and think just your battery is low won't notice it that much, but if your takin a long ride , well you're gonna find youself stranded soon the alternator will not be able to charge the battery and the car will just die . that's the hard way to find out
but I believe if you've got the car running and you disconnect the battery and the car just dies. it's the alternator. if you do the dame thing and the car kinda runs on a bit after the battery has been diconnected, it's the battery. don't quote me on this I could be wrong
Dennis
Buy my stuff plz...
Mondaswap For Sale - MPFI, 88-91 CRX, 92-95 Civic Parts
Please don't PM/Email/IM me for technical support. Make a Post!!!
91 CRX DX, 03 Civic EX
"There are 10 kinds of people in the world: those who get binary and those who don't."
"Of all my imaginary friends I don't think there was one I didn't end up having to kill"
CRX-YEM is offline   Reply With Quote
Old 10-23-2002, 12:25 AM   #4
Rep Power: 28 paragus is off the scale
what happening to your car?
Cankles are sexy.
Pep Boys - "We're rice people"
Asthma is sexy.
paragus is offline   Reply With Quote
Old 10-23-2002, 01:13 AM   #5
actually, its my winter beater (dont drive my civic in winter), it doesnt start, but when I jump it, it is fine, but once you turn off the engine and try start it again, it wont start and it needs to be boosted.
Old 10-23-2002, 09:29 AM   #6
CRX-YEM's Avatar
Ride:  91 CRX
I'd try the battery first, since they are cheaper to replace.
if the problem still persist get a new/rebuilt alternator.
Dennis
Buy my stuff plz...
Old 10-23-2002, 11:58 AM   #7
Rep Power: 24 djextremity is off the scale
Send a message via AIM to djextremity
just take the car down to autozone/misc. street corner parts store. they have a machine that tests the system and tells you what the problem is. if you have a voltmeter and want to do it yourself, then you can go outside with it and test the voltage at the battery. should be 12-14 volts. then turn the car on and test the voltage at the battery positive terminal and a chassis ground. should be 14-18 volts. have someone (or you can) turn on the lights, the radio, and the AC and test it again. should drop a little bit. if the voltage is less than 12-14 with the car off it is your battery. if it does not pick up a couple of volts when you turn the car on, it is your alternator. if it drops out a lot when you turn on accessories, you may have a short or a bad ground somewhere.
djextremity is offline   Reply With Quote
Pinout from "enginebay" plugs to ECU? FastRCars HYBRID -> EG-EK / DC 9 07-18-2005 05:23 PM
iBook battery recall... pills_PMD Computers, Games, Electronics etc 1 05-21-2005 09:48 AM
battery?? alternator?? PLA5151 HYBRID -> EG-EK / DC 5 04-19-2005 06:30 AM
Battery Dying, Possible Causes? Hexen General Tech and Maintenance 6 09-04-2004 04:02 PM
Battery Light, not alternator simplico17 ECU's, Electronics, and Tuning 7 10-28-2003 09:27 PM
