#1 | |
ok guys ive been looking at these, and ive only seen a few on ebay, but how come they only come with like 3-6 ft of negative cable, but like 12-20 ft of positive cable, why so short on the negative cable? also i dont know if one kit is gonna be better than any other so if anyone knows a good kit or has done it, could you tell me how hard the install is? thanks.
91 CRX si 95 Integra LS I DO NOT answer tech questions via PM. Use the forums!!! Quote:
get a free flatscreen, yes it works! Please give what you can to the Tom Cote Medical Fund http://honda-tech.com/zerothread/1828476 |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
Because you can ground to the chassis (anywhere), but the positive lead has to run to the cable that it was connected to in the engine bay.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
umm I believe because you run a 12-20 ft of positive cable for power up front, to save space no battery, then you can run the ground from the battery to somewhere in the back, like a good bracket of a seat or something like that, this is just I have heard but not positive.
When this is all over I think we should get an apartment together. |
#4 | |
so where does the negative cable from the engine bay go? also after you run the cable from the engine bay to the trunk, how would you connect the two cables? also how hard would running the wire be?
#5 |
on my 92 civic, one wire from the negative cable goes to the underhood fuse box, and the other bolts near the top of the wheel well. you should be able to ground it anywhere on the chassis.
.....deagle..... |
#6 | ||
also, since you brought it up, since the negative cable connects to more than one place, would it matter to the things it connects to, for example a fusebox? also after the relocation, where should i connect the negative to? any specific place that would work? someone give me a specific place that would work without me having to drill a hole somewhere, thanks.
#7 | |
take it off. <!--QuoteBegin-GSRCRXsi@Feb 1 2003, 06:51 PM also, since you brought it up, since the negative cable connects to more than one place, would it matter to the things it connects to, for example a fusebox?[/quote] ground the fuse box to the hole that it was already grounded to.
.....deagle..... |
#9 |
its only really good on front wheel drive cars if your gona put a turbo inthat spot. other that that id leave it in the front. the more weight that is distributed in the front the better traction.
my car is slow but ill kick your ass. |
#11 |
RETIRED
4th gen batteries are in the way, 5th gen + aren't.
the purpose of moving to the back is for room, and a little help in weight distribution. batteries weigh liek 40 lbs or so.. so taking it to the back is effectivly an 80lb difference (off front, add to rear) helps even out the balance a little bit. |
#12 |
Ride: 93 del Sol Gas sipper
This is a pretty much must for anyone doing a h22 in a civic and not using it as a strickly drag car.
Collin Material Science and Engineering Michigan Technological University |
#13 | |
ok guys thanks for your help, but has anyone on here ever installed one? i was jus wondering if it was hard. also i was wondering if you car run the cable through the car or would you HAVE to go outside the car, because ive heard that you cannot have a power wire run through the car. someone please help. also i see many different kits on ebay, are they good or are they shit? i see some that look to have everything, but then again i dont know everything that is needed. is any kit superior to any other? any and all help will be appreciated, thanks.
#14 | ||||||
Hope all this helps....
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'> Good Job!! you are here by referred to "turbo_mustang.com! Make sure to get you prize at the door, its a blown engine boosted to 20 psi on stock internals!! To answer your original question, the cheapest way to get a 300 hp honda is to got to your local track and give blowjobs for parts. Find another forum. </td></tr></table><div class=\'signature\'>(timEspeed, a long time ago) Party like it's '88 - '91 <span style=\'color:red\'>Long live Section 8!!!</span> |
#15 |
ok go to your local parts stor buy ten or 12 feet of battery cable and a trailer battery box
first you make sure the bat is bolted down or your dead if you gat in an acdnt that thing will kill you if run power cables away froom stereo wires ( it will prevent interfernce) the drill a hole to the out side of the car and run the vent tube yes you need one batterys have to be vented and unless you want to suck up fumes and shit vent it next seal the box add battery and you done dont remove the ground fronm under the hood just cut if at thr right length and ground it under a bolt |
| Battery Relocation on CRX | MugenCRX | General Tech and Maintenance | 8 | 05-08-2004 09:07 AM |
| Battery Light, not alternator | simplico17 | ECU's, Electronics, and Tuning | 7 | 10-28-2003 09:27 PM |
| remote battery kit? | machine | HYBRID -> EG-EK / DC | 4 | 08-04-2003 12:35 PM |
| Battery Light? | vdubber | General Tech and Maintenance | 1 | 06-18-2003 09:41 PM |
| Who Uses An Aftermarket/performance Battery? | 1991AccoLudeCoupe | ECU's, Electronics, and Tuning | 5 | 05-16-2003 05:26 PM |
