Yeah, i just replaced my sparkies with some nice NGK Iridiums and I find that one of my spark plugs has some oil on it, so Im pissed. I know that this can be either a leaky headgasket, ring, seal, etc.. but what is the easiest way to determine the exact cause of the leak? I have never done internal engine work, only bolt-ons and ghetto-fabs so this would be a new adventure for me. I was thinking of just prettying the car up and selling it asap but I figured I would ask..
Ladies love H22. 94 Honda Accord - H22 swap, AEM V2 intake, NGK iridium IX plugs and high performance wires, custom exhaust, megan headers, jag tailights, rollin' on 16x7s |
Ride: gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
I had this happen on my old b16. I replaced the valve cover gasket, including the 4 little o ring gaskets for the spark plugs, and this fixed me. a cheap and easy fix!!!
#3 | |
!!YTINASNI
If the oil was on top (the part of the plug that is outside of the head), its a bad valve cover gasket. you're looking at $25ish for the gasket set. Four bolts/10 minute job. If it was inside the head its anyone's guess. Valve seal/head gasket/rings.. hell, we could go nightmare scenario and even say cracked block or head.. So where on the plug was the oil? did it look fresh or was it crusty black buildup?
#5 |
Lost in a sea of rednecks
Ride: 5th Generation Honda Civics
People seem to freak out when they see oil on the threads. That's just the oil running down the spark plug when you removed it. You need the spark plug tube seals that come with most valve cover gaskets. Look down the tube and you will most likely see a slight (or worse) stream of oil running down. If it was an internal engine problem, the oil wouldn't stay around very long with the extremely high combustion temperatures. It would find it's way out the exhaust. One quick question to verify no leaking valve seals: Does it blue smoke on initial start up after sitting, say, overnight?
#6 |
The G37....
Ride: Black G37, '07 R6
i'm having the same problem so i won't start another thread. i have oil on at least 1 of the plug wires. would this narrow it down to a valve cover gasket or should i replace the spark plug gaskets to? and are these in stock at shucks or autozone or do we have to go to the dealer.
I changed the page layout. let me know what you think. I need feedback. www.obamacies.com |
#7 | |
!!YTINASNI
you need a "valve cover gasket set". It comes with a new valve cover gasket along with the spark plug hole gaskets, and new rubber hardware for the bolts.
Being that it is a non-load gasket I wouldnt worry about going OEM honda. I've installed two sets from auto-zone and haven't had any trouble with either one. Get the "felpro" ones. They make nice gaskets. Now for timing belts and head gaskets, for sure hit up the dealer. Hope that helps. __________________
#8 | |
The G37....
#9 |
If it runs bad and this oil had anything to do with it, it may be because the wires are ruined. I have always been told that plug wires need replaceing if ever saturated with oil.
#10 | |
I wear stretchy pants
Ride: chevy s-10
happened to me awhile back, it was a bad valve seal. The oil was in the threads. not on the prong,obviuosly cuz it burned it off.
#11 |
So how did the oil defy gravity and work itself upwards and through threads? Did you figure this out and fix yourself or did a shop tell you this?
#12 | ||
Ride: chevy s-10
#13 | ||
Ride: chevy s-10
| spark plugs | DravenVX | General Tech and Maintenance | 5 | 11-10-2005 11:28 AM |
| Which spark plugs? | mozzandherb | General Tech and Maintenance | 5 | 06-29-2005 07:15 PM |
| Spark Plugs | 4DRB16A | General Tech and Maintenance | 1 | 12-29-2004 10:09 AM |
| Best Spark Plugs To Use | MokujinX5 | Engine Building | 2 | 06-23-2003 07:06 PM |
| Iridium Spark Plugs Or Regular Spark Plugs | Drenni | ECU's, Electronics, and Tuning | 6 | 04-21-2003 01:39 PM |
