my clutch is very spongy and has to be push in all the way before going into gear.
i already bled the lines but it's stil the same. somebody mentioned bleeding the master cylinder. how do i do that? and what is reverse bleeding?? ![]() |
Ride: 93 del Sol Gas sipper
Check on the floor of your car to see if you have any leaks. If there is any residue of brake fluid (blistering paint, wetness, ect) then your Clutch master cylinder is out. Other thing that it could be is your slave cylinder. It is the part that you bleed the line from.
Reverse bleeding is a process in which you pump brake fluid INTO they bleeder screw, and have it all go out the resivior. I am not sure if you can even do clutches because the slave cylinder bleeder screw is a one way screw, so when you bleed, you can just pump and pump and not do the pump pump, hold rutine. Make sure when your bleeding, you never have the fluid go below minimum. __________________
Collin Material Science and Engineering Michigan Technological University |
#5 |
and also watch out for brake fluid squirting out of the screw like a porn and hitting your buddy
#6 | |
B happy
Ride: dohc 95 egg
Speaking from some kind of experiance? hehe__________________
#7 |
actually yes, buddy was pushing the pedal assembly in, I opened the pin - BLOT!! all on my leg
![]() __________________
| clutch problem after swap | welfare | HYBRID -> EG-EK / DC | 0 | 05-12-2004 11:51 PM |
| My transmission or clutch is acting up | La_Pieuvre | General Tech and Maintenance | 6 | 02-06-2004 02:40 AM |
| My clutch isn't engaging! | MarkJimenez99 | General Tech and Maintenance | 22 | 12-27-2003 11:25 AM |
| NOPI.com | rsaeini | Members' Lounge | 22 | 10-02-2003 03:07 PM |
| d17a2 act clutch + fly wheel problem | Thechemist | Engine Building | 2 | 06-28-2003 12:39 AM |
