#1 | |
...PENDEJO....
Ride: bagged Ford Ranger Splash
what is a block guard and what is a block girdle? what do they do and whats their function?
***Please leave this section blank. For office use only.*** -BrianE. 1995 Ford Ranger Splash 2009 Ford Focus http://midwestminis.forumotion.com/forum.htm Quote:
Ride: RPS-13
umm.... i know block guard is usually a cheap insurance policy for turbos, and its basically an insert if you will for between the sleeves and the block. i think
and i have no idea what a block girdle is. __________________
-Scott (O=O/RPS 13\O=O) ....finally SR'd http://www.nissanpacific.com --- for the nissans http://www.myspace.com/SkylineScottro -- My MySpace account durrrr. |
#3 | |
Admin with a big stick
Ride: 2003 S2000
Block girdle = a brace that goes on the bottom of the block. It usually connects the crankshaft mains together so that they are less prone to move about. More crankshaft stability = more reliability at high revs. The GSR, ITR, and CTR come with block girdles stock. You can get aftermarket pieces for other B blocks. Block guard from Golden Eagle: ![]() ![]() Aftermarket girdle from Z10: ![]() __________________
#4 | |
...PENDEJO....
thanks for the info guys!
now would any of these be practical for a mildly built LS motor or would i be wasting my time with buying one...in particular the block girdle? __________________
#5 |
yeah, coudln't have said it better myself - Calesta
also, saw some show where some shop actually drilled into the block, put in studs around the top of the sleeves, so that the sleeves wouldn't move as much in upper rpms. Seemed pretty cool, for a DIY __________________
#6 | ||
Yep, that's called posting the block, used alot in NASCAR I believe.
It's back! Keep up on the progress of my cars! http://civicminded.wordpress.com/ Quote:
#7 |
Ride: 2003 S2000
Larry over at Endyn likes to post blocks. Go hit up his page and you'll see it: www.theoldone.com
He sells a stud kit that matches your block material for about $35. To me, it's better than using a block guard- if you install the studs correctly, there's no need to bore your block again. __________________
