Facebook Twitter
Can i run a d16y8 with Obd0
This is a discussion on Can i run a d16y8 with Obd0 in the General Tech and Maintenance forum
Scenario- 16y8 head(aem adj cam gear) D15b2 block Mpfi swap into dx(obdo) 90si intke mani 90si trans pm6 ecu Will this work? If so is there anything i am missing?...
Old 07-14-2005, 04:38 PM   #1
Thumbs up
Scenario-
D15b2 block
90si intke mani
90si trans
pm6 ecu
89cmutr is offline   Reply With Quote
Old 07-14-2005, 04:41 PM   #2
Yeah i know im new! Sorry for the 2 post mess up!!!!!
Old 07-15-2005, 12:35 AM   #3
Calesta's Avatar
You need something to activate VTEC, and you'll probably want to chip the PM6 to a P28 fuel map.
Old 07-15-2005, 12:49 AM   #4
MikeBergy's Avatar
Originally posted by Calesta@Jul 14 2005, 10:35 PM
[b]You need something to activate VTEC, and you'll probably want to chip the PM6 to a P28 fuel map.
use turboedit to activate vtec through the a/c switch on a chipped pm6. Search PGMFi.org. Ask Jason Parker, or Xenocron, I'm sure there are more, those are the only two guys I personally have chatted with though.
MikeBergy is offline   Reply With Quote
Old 07-15-2005, 10:57 AM   #5
thanks for the tips guys
© 2001-2013 HondaSwap.com
