Can a Lost Motion Assembly go bad?
Old 04-21-2004, 06:52 PM   #1
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
just wondering because there has been an annoying rapping sound coming from my head. (1g b16a) i have titanium retainers and dual valve springs installed along with comp cams stage 2 camshafts. i've checked the valve lash several times and everything is within spec. so my question is... with the higher lift of these cams... could or can the LMA's go bad or become worn out?
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 04-22-2004, 12:43 AM   #2
Rep Power: 19 cws13 is off the scale
Send a message via AIM to cws13
I have never seen or heard of it. If you have a very agressive ramp on your cam profile you can chew up the whole valve assembly in time. Not really with those cams though.
1320 Motorsports Athens,GA
<a href=\'http://www.1320motorsports.com\' target=\'_blank\'>1320 MOTORSPORTS</a>
cws13 is offline   Reply With Quote
Old 04-22-2004, 07:42 AM   #3
Ride:  '92 Civic CX
valve assembly meaning rocker arms etc...
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 04-22-2004, 12:29 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Yes, LMAs can go bad. If you want to do a quick check, press down on the LMAs through your followers, and make sure that none of them are sticking. When you go with larger cams, you generally want to get ITR LMAs. They have a bit more clearance for larger lobes. With cams that are about ITR sized, you can use stock LMAs- for larger cams, it's safer to use new ITR LMAs. I had a funny noise in my B16's head, and it turned out to be sticking LMAs.
If your LMAs are sticking and you don't want to spend cash buying new ones, you can try to refresh them by removing and soaking them in a tub of fresh engine oil overnight. Sometimes that helps them to loosen up.
Old 04-22-2004, 12:40 PM   #5
Rep Power: 20 97CTR is off the scale
What valve lash are you running?
97 ex coupe
Wire tuck in progress....
97CTR is offline   Reply With Quote
Old 04-23-2004, 07:11 AM   #6
Ride:  '92 Civic CX
int.: .006 in.
exh.: .007 in.
stock specs... i have a feeling the LMA's are bad.
It sounds like the cam is "slapping" the rockers arms. I'll pull the valve cover off today and see what i can find out...
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 04-23-2004, 08:59 AM   #7
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Originally posted by DTEC@Apr 23 2004, 12:11 PM
int.: .006 in.
exh.: .007 in.
Keep us posted, when I switched to CTR cams there was a lot more valve noise coming from the VC than before using stock B16A valve clearance specs, maybe it has something to do your issue.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 04-24-2004, 02:28 AM   #8
Ditto, new one on me. I'd like to know what it turns out to be. Good luck.
Lost motion assembly CRXSIR1 Engine Building 15 02-17-2008 09:32 PM
Sudden power lost? CRX Si '91 ssl2k General Tech and Maintenance 16 03-30-2004 09:44 PM
Simple Harmonic Motion. Loco Honkey Members' Lounge 2 01-15-2004 01:05 AM
pedal assembly ef9civicgen4 HYBRID -> ED-EF / DA 1 09-23-2003 12:18 AM
Motor Assembly? JDMilan Members' Lounge 13 06-05-2003 03:55 AM
