My car wont start it just cranks. i checked the fuel and its getting presure at the hose by the filter and i checked for spark and it was really weak. I tried replacing the distributor coil and it didnt fix it, i tryed replacing the ignition control module and it didnt fix it. what else could it be? it ran fine then sat 1 year and is now doing this. i need to get it fixed asap. car is not throwing a check engine lite or anything either.
#2 | |
universal logic protocol
Ride: 99 VW GTI 07 Jeep Compass
Try cleaning the plugs if that still doesn't work try new plug wires then new plugs.
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now 07 Jeep Compass If you ever find anything I write usefull please leave rep. Rebuilding a Transmission http://www.the-whiterabbit.com |
plugs are good and wires are ok it is getting weak spark right off the distributor to the wire. i took one wire right off the distributor and put it up to the distributor to check the spark and its a slow thin spark with no snapping noise my other civic the spark is faster bigger and snaps loud this one is not like that.
Beast
Ride: Stuff
Hmmm. Try disconnecting the grounds and resurfacing them? I had a recent problem similar to yours with a truck not too long ago and that's what I did. I also added an extra ground for shits and giggles.... works great now.
#6 |
yeah i put in new gas and i am getting fuel and i check the spark and it was really weak so i replaced the coil and the ignition control module and it didnt change. the plugs are new and the wires are in good shape is there anything i am missing or is the whole distributor junk. is there anything else that would cause weak spark? i checked the spark right off the cap to the wire and it was weak there so wires/plugs havent even come in to play yet it is weak right off the distributor.
#7 |
Sat for a year huh, I would check compression on the cylinders. Sometimes when cars sit for a long time the oil dries up around the rings and you loose compression. Kinda like washing out the rings when flooding an engine. However i have only seen this happen on a volvo, the solution there was to add a cap of oil to each cylinder and try again.
Got my swap!!! Needs to be faster.
| Have the l337's hAx0rEd me? (I need a code reader) | klyph | Computers, Games, Electronics etc | 12 | 03-27-2007 07:47 PM |
| engine cranks but wont start! | mustang67n | Civic and CRX - EF | 2 | 07-07-2006 03:48 PM |
| engine cranks but wont start! | mustang67n | Civic and CRX - EF | 1 | 07-02-2006 03:46 PM |
| B16 Cranks, but won't start | Citizen_Insane | HYBRID -> ED-EF / DA | 6 | 04-07-2004 02:11 AM |
| Engine cranks, but car won't start | sbaker0421 | General Tech and Maintenance | 20 | 01-23-2004 12:04 PM |
